Old 08-05-2005, 12:02 AM   #1
xagna
xagna has a little shameless behavior in the past
s13 doing 0.95G + at skidpad! 73mph at slalom!
I read an article about this s13 on this month's issue of sport compact car megazine. The white 90' with SR , according to the magazine, was able to do 0.95G and 73mph with its progressive coilovers.
I have megan coilovers. no other suspension mods yet. How do you think I can pull 73mph and 0.95G ? For those of you with coilovers, what is your slalom and skidpad numbers?
xagna is offline   Reply With Quote
Old 08-05-2005, 01:40 AM   #2
Irukandji
do you know what tires the car was running? im pretty intersted.
Old 08-05-2005, 10:07 AM   #3
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
The tires are going to be a huge part of that. I remember an old 510 with a 13B did 1G on the skidpad thanks to its Hoosier race tires in some Sport Compact Car event.
If you want to hit those numbers, get some race slicks, and start dialing in your alignment until you get there. The usual host of parts will probably be needed as well. Stuff like swaybars, and adjustable arms for the alignment settings you will need.
That is just a very basic formula, what will actually work for your car and the surface you are testing on is a whole mess of variables.
SpeedMonkeyInc is offline   Reply With Quote
Old 08-05-2005, 10:33 AM   #4
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
from what i understand, the key to big skidpad numbers is suspension with alot of give and extremely huge meats. like 275's all around.
They did something like this w/ a 350z a while back, w/ just bushings, sway bars and HUGE street tires all around (equal sizes) they pulled 1G or so
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 08-05-2005, 11:52 AM   #5
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
That car is on RA1s. Actually, most of the cars in that article were. Pretty unrealistic IMO to have the "cheap project street cars" on expensive R comps.
turtl631 is offline   Reply With Quote
Old 08-05-2005, 12:29 PM   #6
S14DB
AFC #1
S14DB's Avatar
It's a good way to skew an article. Which SCC is known for.
Old 08-05-2005, 12:56 PM   #7
the head
the head's Avatar
r compound tires are not any more expensive than other high performance tires I switched to A032Rs because they were cheaper by about 20 each than the potenzas I used on my transam
Old 08-05-2005, 01:00 PM   #8
ZK
ZK's Avatar
ZK is making a name for him/her selfZK is making a name for him/her selfZK is making a name for him/her self
Better get some really good seat and harness to hold you in. You're gonna need it. With factory S13 seats its a struggle to stay in the seat at half a G.
ZK is offline   Reply With Quote
Old 08-05-2005, 02:29 PM   #9
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
i remember one of the magazines contributing the high g reading on the skidpad for a viper to its massive amounts of torque allowing it to correct with slight tap of the throttle for oversteer in the skidpad
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 08-06-2005, 12:42 AM   #10
xagna
What does "dialing in alignment until you get there mean"?
Old 08-06-2005, 01:54 AM   #11
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Sometime you just wont have enough camber, so you have to dial it.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 08-06-2005, 09:24 AM   #12
Ian
"dialing in" means to adjust to personal specification based on the results of testing.
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Old 08-07-2005, 01:22 AM   #13
turtl631
Yep, you can futz a lot with toe/camber/caster to alter cornering grip, balance, and various other handling characteristics.
While some R comps are cheaper than some street tires (i.e. expensive Michelins, BF Goodrich), you can generally find a sticky street tire for way less than R comps. For example, Kumho MX is a good sticky street tire with high heat tolerance, and they cost less than any R comp out there. Ditto for Hankook Z212 and Falken Azenis, albeit without the heat tolerance.
Old 08-07-2005, 02:07 AM   #14
wootwoot
Sorry to wander off topic but do the Kumho MX's share any major similiarities with their other tires? Ive had decent expierence with their lower price tires but they seem to bubble easily from impact(pot holes)
Old 08-07-2005, 08:04 AM   #15
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
i run azenis sport's and got em for 80 bucks each.
and yes, they stick like glue.
MakotoS13 is offline   Reply With Quote
Old 08-07-2005, 09:34 AM   #16
HaLo
from Canada, eh!
HaLo's Avatar
You don't know what's a sticky tire until you run some Hoosiers...
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 08-08-2005, 03:55 PM   #17
xagna
Thanks for your replies.
I am interetsted in learning some more about suspension geometry and tuning.
Searched for informations and found some bits and pieces here and there.
Is there any book or website with comprehensive infos about the suspension geometry and tuning?
Old 08-08-2005, 04:41 PM   #18
OptionZero
OptionZero's Avatar
haha Makoto I got my Azenis for $77 =P
I had to pay shipping though...damn...
