Old 10-03-2001, 02:25 PM   #1
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
i'm thinking about having a guy do a custom cat-back for me instead of buying an n1.  I was wondering if you all knew what size piping i should get for a NA s14.  Is 2.5 too big?. what is it stock? and what kind of muffler should i get? thanks!
AJ is offline   Reply With Quote
Old 10-03-2001, 02:37 PM   #2
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
2.25 - 2.5 inches should be good. As for the muffler get free flowing muffler, and what ever kinda muffler looks good to you. <img src="http://www.themelee.com/smilies/s/otn/violent/spectator5.gif">
ca18guy is offline   Reply With Quote
Old 10-03-2001, 04:28 PM   #3
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I say bump it up a notch.  Our 2.4L processes alot of gas, so a 2.5-2.75" should be perfect.  Our cars have a weak top end...so the faster we can pass gas (for lack of better terminology :biggrin:) at higher rpm, the more hp we'll make in the higher rpm range.  Torque benefits from gas velocity...the narrower the pipe, the faster the velocity given the same amount of gas.  However, since our cars have a good bit of torque, we can afford to go with a larger diameter to benefit the top end hp.
LanceS13 is offline   Reply With Quote
Old 10-03-2001, 07:18 PM   #4
konkman
konkman is an unknown quantity at this point
Unless you plan of force feeding your intake (turbo), I'd stick with 2.5, but if thats your goal, just keep it under 3.
konkman is offline   Reply With Quote
