Old 01-21-2015, 10:20 AM   #1
JayDM420
JayDM420 is an unknown quantity at this point
Valve Spring Removal W/ Head on
So I've got a Redtop S13 Sr20det that I have been building to install in my S14.
I bought the Bc stage 2 cams and Bc valve springs kit. I have the motor un-installed for easy access but I would like to install the springs without removing the head if possible. When I searched around for a guide for doing this I came up with the nicoclub thread on How to build a 9000rpm Sr20det Head
http://www.nicoclub.com/archives/how...0det-head.html
I have the tool in the red box that bolts onto the head to remove the springs but the only info this guy gives on removal with the head on is this
"First, stuff a tower underneath the valves that you are working on so that the valves do not move. If you are doing this with the head still on the motor, you NEED to pressurize the combustion chamber so that the valves don’t fall down."
How exactly do I do this on a Sr? What kind of attatchment am I going to need for my air compressor/where can I buy it? Where do I stick it lol? Any info would awesome
JayDM420 is offline   Reply With Quote
Old 01-21-2015, 10:28 AM   #2
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Just take the head off!
It's much easier, at least for me it is.
Dboyizmlg is offline   Reply With Quote
Old 01-21-2015, 10:40 AM   #3
JayDM420
It may be easier but it is certainly not cheaper lol
Old 01-21-2015, 11:05 AM   #4
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Compression gauges will usually come with a short hose extension. One end of the hose extension screws into the sparkplug hole, the other end has a pneumatic hose fitting.
dbeiler is offline   Reply With Quote
Old 01-21-2015, 11:11 AM   #5
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
I've had friends who had luck taking the spark plug out, threading string down in there when the piston is at BDC, then rotating the motor to TDC so that the string keeps the valves pushed up. Never tried it myself though
pacotaco345 is offline   Reply With Quote
Old 01-21-2015, 11:15 AM   #6
JayDM420
That almost seems to simple lol. Just connect em and flip the switch for the compressor? Should I get the cyclinder I'm working on to TDC before compressing the spring?
Old 01-21-2015, 11:21 AM   #7
PPman
PPman is an unknown quantity at this point
I did it on my ka with a air compressor, and a compression test hose from the cheap harbor freight kit. Putting the piston you are working on at TDC would be worth the extra safety, since your engine is out you should be able to get away with just that (TDC that is). Give it a try if you already have the compressor and fittings.
PPman is offline   Reply With Quote
Old 01-21-2015, 11:29 AM   #8
JayDM420
Alright this doesn't seem nearly as complicated as I anticipated, thanks for the info guys I really appreciate it!
