Old 07-05-2004, 01:41 PM   #1
nissandrift
nissandrift is an unknown quantity at this point
Send a message via AIM to nissandrift
cracked front lip
I just got a stock pignose lip this weekend from a freind, but it has a decent size crack on the corner. What can I use to fix it, and will hold up. I don't need it to be perfect, just not noticable from a distance.
nissandrift is offline   Reply With Quote
Old 07-05-2004, 01:48 PM   #2
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
there are different ways to do it depending on the crack
for some, you can use a plastic welder and heat both sides and stick em back together
SEM makes a product called plastic bumper repair. it comes in an epoxy tube and you basically glue both sides back. this stuff also works like a flexible bondo, so you can smooth it all out too
you can always frankenstein it back together by drilling holes and using zip ties (preferred method due to easy )
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 07-05-2004, 07:29 PM   #3
nissandrift
anyone else have any opinions, I don't have access to anything for plastic welding, and zip ties will be a little more noticeable than I'd prefer.
Old 07-05-2004, 07:34 PM   #4
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
stitch it with wire. my friend did it to his e30, now we call it scarface.
citizen is offline   Reply With Quote
Old 07-05-2004, 07:38 PM   #5
SaintlyCharBoy
it doesn't get much easier than that man - the junk works like epoxy, yet stays flexible so the bumper doesn't shatter when you hit more stuff
the other big thing is what does the crack look like? is there a gap or do both sides meet perfectly?
do you have skillz with fiberglass, that is another option.
there really are several ways to go about this, however, all take a little work
95 base - retired
Old 07-05-2004, 07:45 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
zipties and a drill
Old 07-06-2004, 07:50 AM   #7
nissandrift
One of the cracks come together tight, but the other is like a 4 way crack and they are close except where they meet its almost a dime size hole.
Old 08-12-2004, 10:39 AM   #8
FallbrookS13
FallbrookS13 is an unknown quantity at this point
Send a message via AIM to FallbrookS13
when i had that lip on my s13 it broke probably 8 times. the lip was actually in 3 diff pieces. i used drill and zip ties to rebuild it everytime. o yeah and a lot of black ductape. key is to not mount it on your car very firmly... incase of incident it just falls off instead of breaking.
hi.
FallbrookS13 is offline   Reply With Quote
