Old 02-15-2015, 07:48 PM   #1
mo13007
mo13007 is an unknown quantity at this point
91 MR2 Upgraded turbo 94+
Will consider all trades. $7000 with the rpf1s $6000 without. Make me a reasonable offer.
Selling my 91 Mr2 Turbo. This is a factory turbo car, not been swapped. I got it October last year in a trade. Its has a clean and clear title that has only one accident reported. I have the car-fax to prove this. 187414 It was originally a Florida car, and has only been there and in Georgia, so it has absolutely no rust. T-top car with manual windows and a manual rack. When I got this it had a JDM ceramic wheel ct26 with bad seals and lousy intercooler couplers and clamps. It still pulled great and didn't have any problems, but the turbo needed addressing. So i bought a TD05 turbo kit from ATS racing. With all the supporting mods as follows:
ATS Racing TD05 Kit:
Stainless coolant and oil feed and return lines
Exhaust Manifold Adapter
Tial 10lb Wastegate
ATS bored fuel rail and 50 psi fuel pressure regulator
ATS 550cc fuel Injectors
ATS TD05 Mitsubishi Turbo
ATS ROM Tune
Aftermarket Intercooler with Fan Shroud and 2.25" Pipes (it was installed on the car when I got it, Its eaither a nice ebay one or a KO Racing)
Aeromotive FPR set at 50 psi (have the ATS FPR as well)
Walbro 255 lph fuel pump
KO 3" Intake pipe with filter
KO EGR Delete
ATS Throttle Body Inlet
3" Phoenix Departure Complete Exhaust
The motor is very healthy, had the timing belt done at 176k along with new engine coolant hoses, owner before me has this paperwork. Its only running 10lbs of boost off the wastegate spring and pulls super hard, holds boost until redline unlike the ct26, and is very responsive. I don't know what mine is putting down but others with the same kit and similar mods are getting 250whp. Google it and you will find some dyno charts. I estimate it's close to 250whp. I have a manual boost controller from ATS I haven't installed. I don't find the need to increase the boost. It's a blast to drive on 10lbs. The ROM tune is good for 17 pounds of boost on 93 octane fuel. On 17bs the car should be putting down close to 300whp. With the ROM tune there is not fuel cut, factory redline is increased to 7500, and the is no speed limiter. Everything else that is on the car is as follows:
BC Racing BR coilovers with extreme drop kit (shorter front springs) 8k, 10k, and 12k springs
twos2us Reproduction floor mats
Ashtray Gauge Pod
Replaced RPM Capacitor
White LED Gauge Cluster Lights
Prosport Mechanical Boost Gauge
Innovate LC-2 Wideband
Front and Rear Crash Bolt Kit (unlimited camber adjustment)
Prothane Polyurethane Bushing Kit (replaces all the bushing on the car)
New Tie Rod Ends
New OEM Front Ball Joints
New OEM Alternator from Toyota
Optima Red Top Battery
New Enkei RPF1s with New Yokohama S-Drives 17x9 +22 offset up front and 17x10 +18 in the rear
(also has 5mm hubcentric spacers up front to help clear the strut)
Muteki NeoChrome Lug Nuts
JDM Perforated Leather Seats and Door Cards
JDM Climate Control
93+ Style Front Lip (its slightly bigger than a 93+ lip and fiberglass)
94 JDM Rear Spoiler and Trunk Lid
94 JDM Taillights and Center Panel
All this stuff has less than 5000 miles on it, turbo has around 3000 miles on it. The car runs and drives great, starts every time, and never has let me down. It's the perfect drivers car, super fun to drive, handles great and has everything you want and nothing you don't need. It's not perfect, but the paint is in really good shape, not faded or dull. It does have small dings hear and there. With all the good thing there are some bad:
The T-Tops leak slightly when you wash the car or when it rains really hard. The few times I've driven it in the rain they did not leak. I bought some Honda Shin-Etsu to help the seals and it seems to help.
The holes for the factory spoiler are still in the quarter panels and are plugged.
The AC doesn't work. I've never used it, if the weathers nice I take the tops off. There's a dent in the condenser so this might be the cause.
The front bumper has some damage on the bottom, the paint has came off in spots and the center grill is broken.
3rd Gear Synchro grinds when you go in aggressively and on high rpm downshifts, it shifts perfectly any other time and if you rev match its not as bad. This is very common in all Toyota transmissions from this era. I was saving and looking for a LSD trans unit to swap in.
Has Airbag light on. It came on after I disconnected the battery once and hasn't gone away. (I will probably have the fixed soon)
The Wideband quit working, I sent it to Innovate and they didn't find anything wrong. I think there's a break in the signal wire to the gauge. The unit has proper power and functions as it should just won't give a readout.
mo13007 is offline   Reply With Quote
Old 02-16-2015, 10:01 AM   #2
dizzariot
dizzariot's Avatar
Trader Rating: (47)
dizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfection
Feedback Score: 47 reviews
I'd gladly park this next to my S13...
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
dizzariot is offline   Reply With Quote
Old 02-16-2015, 11:02 AM   #3
Rich260z
Rich260z is an unknown quantity at this point
What size are they tires? they look pretty stretched.
Rich260z is offline   Reply With Quote
Old 02-16-2015, 01:29 PM   #4
mo13007
Buy it and please do.
They are just 215 40s and 235 40s. They are s drives which are know to run a little wide.
Old 02-16-2015, 04:55 PM   #5
CSAlltrac
CSAlltrac is an unknown quantity at this point
Hope she finds a good, loving home. Very clean
CSAlltrac is offline   Reply With Quote
Old 02-16-2015, 05:20 PM   #6
dizzariot
dizzariot's Avatar
Trader Rating: (47)
For your price I totally would if you were in CA. GLWS.
Old 02-16-2015, 06:43 PM   #7
mo13007
Thank you. I hope she does as well.
Thank you. I wish I was in California as well.
Old 02-16-2015, 07:19 PM   #8
projectslider
projectslider is an unknown quantity at this point
This is beautiful.
Im in sc and would grab this in a heartbeat if i wasnt on the market for a house.
Who knows. If its still available i could",, rad machine man
projectslider is offline   Reply With Quote
Old 02-16-2015, 08:03 PM   #9
mo13007
Originally Posted by projectslider View Post
This is beautiful.
Thank you. You know a little red sports car goes good with houses. I wish someone would grab it up before it becomes no more.
Old 02-17-2015, 08:51 AM   #10
DrftKingIII
DrftKingIII's Avatar
DrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura about
Seems like a good price for a nice car! Wish I had extra money and space.
- このノイズをファック -
DrftKingIII is offline   Reply With Quote
Old 02-17-2015, 08:42 PM   #11
Tosunian5
Tosunian5 is an unknown quantity at this point
BUMP for a cleeeean ass MR2!! Don't part out this beauty man!
Tosunian5 is offline   Reply With Quote
Old 02-17-2015, 09:35 PM   #12
mo13007
Thank you I wish you did too.
Thank you. All the support is making me not want to. Its means a lot everyone.
Old 02-18-2015, 07:39 AM   #13
skrip
skrip is an unknown quantity at this point
Too clean to part out. I just bought one a year back. Loving it! GLWS.
skrip is offline   Reply With Quote
Old 02-18-2015, 05:42 PM   #14
projectslider
Seeing this again tonight. Daanng its awesome
Old 02-18-2015, 06:16 PM   #15
mo13007
Thank you. There really is nothing like it. I've enjoyed every minute of owning mine.
Thank you for the kind words.
Old 02-19-2015, 02:40 PM   #16
fwd-240
fwd-240 is an unknown quantity at this point
if it was in tampa it'd be sold, maybe we could work out a way of getting it here?
fwd-240 is offline   Reply With Quote
Old 02-19-2015, 04:14 PM   #17
wisniaPl
wisniaPl is an unknown quantity at this point
Dont do part out.... such a nice example
wisniaPl is offline   Reply With Quote
Old 02-19-2015, 04:32 PM   #18
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
I'd totally trade... if you were interested in trades. This is a super nice MR2. Good luck!
David48 is offline   Reply With Quote
Old 02-19-2015, 04:47 PM   #19
Gdelva517
Gdelva517's Avatar
Gdelva517 is an unknown quantity at this point
Hey! Im very interested in the MR2 can you please contact me? Asap
Gdelva517 is offline   Reply With Quote
Old 02-19-2015, 06:23 PM   #20
voiddweller
voiddweller is an unknown quantity at this point
Very nice!
97 S14 SE w/S13 Blacktop
04 CL9
voiddweller is offline   Reply With Quote
Old 02-19-2015, 06:50 PM   #21
mo13007
I pmed you.
Thank you. I haven't had to yet and hopefully I won't.
I'd love to take trades. There are many things I want. But sadly my financial situation limits me, and I really need to sell.
I pmed you as well. But for you and anyone else interested my number is 770 653 4071.
Originally Posted by voiddweller View Post
Very nice!
Thank you sir.
Old 02-22-2015, 12:06 PM   #22
turboboxer6spd
turboboxer6spd is an unknown quantity at this point
Don't part out!! Clean and beautiful!
turboboxer6spd is offline   Reply With Quote
Old 02-22-2015, 01:26 PM   #23
mo13007
Thank you. There been some interest but everyone flakes. I'll give this another week or two. I really don't want to part it out. But I may have no other choice.
Old 02-24-2015, 08:31 PM   #24
mo13007
Bump, before a friend gets the rpf1s this weekend and the part out begins. May take partial trades with cash. Clean s13 coupes (only coupes, I'm sorry, preferably with sunroofs), or mk3 supras. May even trade for a swapped mk3 supra.
Old 02-24-2015, 09:04 PM   #25
bigyellowevo
bigyellowevo is an unknown quantity at this point
I can vouch for how clean this car is. If I had the space, I would have bought this. Seller is a true car fanatic, and a legit seller. Good luck.
bigyellowevo is offline   Reply With Quote
Old 02-24-2015, 09:51 PM   #26
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
What the hell? How is this car not pulling this money? Even on the sw20 forums?
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 02-25-2015, 06:20 AM   #27
mo13007
Thank you Robert. I would really hate to see all the work you've put into this go to waste.
Thank you. I don't know. I feel my price is reasonable. And the car looks good. Maybe no one wants sw20s. Even thought they are an absolute delight.
Old 02-25-2015, 03:16 PM   #28
BlackZenkiS14
I almost pulled the trigger on a bone stock one about as clean, but needed maintence, for 6k. If this was local, I'd seriously consider doing it.
GLWS man, it's a nice car,
-Kyle
Old 02-27-2015, 10:20 AM   #29
mo13007
Thank you. I hope it will sell and go to a good home.
Now considering all trades, or make a reasonable offer.
Old 02-28-2015, 07:22 AM   #30
David48
David48's Avatar
Well I just picked one up so if you do decide to part out, shoot me a PM. I'll buy plenty of parts.
