Old 03-10-2015, 11:02 AM   #1
Locally240
Locally240 is an unknown quantity at this point
240sx rb20 help
Ok so before I put the rb20 in ! What are some things I should check, buy , and replace ? Engine is all stock I want to know what should I look at before dropping the motor in ?
So far my list of thing I need are
-walbro 255
- koyo radiatior with dual fans. ?
-wiring specialties harness
- what maf should I use I don't have one
- what else do I need for my 93 hatch rb20 swap also I'm not looking for 300hp I just want stock boost.
Locally240 is offline   Reply With Quote
Old 03-10-2015, 11:59 AM   #2
Locally240
Really wanting to know the plan is to order everything today of what I need thanks !
Old 03-10-2015, 09:28 PM   #3
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Engine and transmission mounts
Driveshaft
Intercooler and piping
Downpipe and exhaust
Radiator to engine block upper and lower coolant hoses
6cyl tachometer if you aren't able to adjust OEM tach
Check the condition of the timing belt, water pump, and spark plugs.
Check the coilpacks for any insulator cracks.
Upgrade the clutch if you intend to drive it hard.
Consider buying bigger brakes and a wideband sensor.
dbeiler is offline   Reply With Quote
Old 03-10-2015, 09:38 PM   #4
Locally240
Thanks , I got ic piping exhuast and mounts and that good stuff,
Will do check timing , water pump and all that thanks a lot !
Old 03-12-2015, 09:03 AM   #5
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
http://www.wiringspecialties.com/r32rb20det.html
there you go regarding the RB20 harness for your car, let us know if you need any help or have questions
wiring specialties is offline   Reply With Quote
