Old 08-04-2004, 03:40 PM   #1
DRFT24O
DRFT24O is an unknown quantity at this point
Send a message via AIM to DRFT24O
s13 Coilover question
Guys im looking for a set of coilovers that will give me more then a 2 inch drop, i was looking at ground control but they only go up to 0-2, where else can i look? also dont hurt my wallet to bad. thanks
DRFT24O is offline   Reply With Quote
Old 08-04-2004, 03:56 PM   #2
Salty_X
Salty_X is an unknown quantity at this point
Ground Controls are just springs with an adjustable spring perch.
Every brand of aftermarket coilover can give you a 2+ inch drop, the cheapest of them being D2/K-Sport brand, which have had a few group buys happening on other forums. Other than those, Tein Basic or Tein SS might be what you're looking for.
Salty_X is offline   Reply With Quote
Old 08-04-2004, 06:08 PM   #3
DRFT24O
s13
When you say ground controls are just adjustable springs with a perch does it make it any different then the other coil overs? and can i get more then 2inches from ground control because look at this 6065.
01 240SX 89-94 8 E 0 to 2 $ 399
6065.02 240SX 89-94 7 E 0 to 2 $ 399
6065.03 240SX 89-94 4 E 0 to 2 $ 399
it says 0-2.
Old 08-04-2004, 07:22 PM   #4
Salty_X
Most coilovers are sold as a set of struts/shocks and springs that are matched specifically for each other, along with some kind of height and damping adjustability. What GC sells is more of a coilover kit than actual coilovers: you supply the struts and shocks, then it becomes a coilover suspension.
As for how low you can go with GC, back when I read tuner mags they always advertised up to 4" drops, but that was probably for Hondas.
But like I said before, you could probably get your hands on some D2/K-Sport or Tein Basic/SS for around the same as what you would pay for the GC system and some good struts & shocks.
Old 08-04-2004, 09:23 PM   #5
DRFT24O
ok cool, so for the D2/K-Sport or Tein Basic/SS, it comes complete with everything i need correct?
Old 08-05-2004, 01:13 AM   #6
Salty_X
Yep.
The following errors occurred when this message was submitted:
The message you have entered is too short. Please lengthen your message to at least 10 characters.
Old 08-05-2004, 01:39 AM   #7
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
well the rears for the d2/ksport doesnt go that low unless you lower the spring perch(eliminate most, or all of the spring preload..) My friend has 17s and car looks like its lower.
dvdevo is offline   Reply With Quote
Old 08-05-2004, 01:42 AM   #8
mrmephistopheles
mrmephistopheles's Avatar
do your own research. there's plenty of information out there.
Old 08-05-2004, 11:19 AM   #9
007jpang
007jpang is an unknown quantity at this point
they also have some great coilovers at
http://www.splparts.com/
the kts coilover, although its
$1040 it worth it in the long run, but if your just getting coilover for looks then just get lowering spring/struts, their cheaper.
But the kinds of suspension you get depends on what your going to do with your car.
007jpang is offline   Reply With Quote
