![]() So my question is,
Is the HKS ssqv4 really universal? I'm doing an SR swap and I'm looking for an aftermarket bov/recirculating valve. Im plan to start with factory 7psi and turn it up a bit. I need flexability. Ive come to understand that because this valve has a diferent pressure management system it can run low to high boost levels. Is this true? How low? And how high? What springs/adjusting is involved? Just so i know.... My SR coupe and I thank you! |
![]() Join Date: Mar 2009
Every bov is universal if installed correctly.
The best way to apply the HKS SSQV on an sr20 is by utilizing the optional recirculation fitting and routing the air back into the intake pipe after the MAFS. It should be able to handle any boost level you could throw at it with your setup. |
Ok i should have stated more specificly. I understand all bov's are "universal" but my expression of universal was towards the psi rating of the valve. And yes, im running recirc for emissions and overall driveability. The BOV doesnt seem to have an adjusting screw so it is either a set psi range or has interchangeable springs OR it doesnt adjust, and it works for a wide range of boost levels
![]() Join Date: Aug 2011
The chances to buy a genuine SSQV are approx. nil .
If you are going to recirc a valve, i would not use an SSQV unless staying at low boost (like less than 15psi). The exhaust port is really small. I am running a recirced Greddy type RS (because it was a second hand, genuine one, for cheap, and came with a hotpipe). It uses 2 springs though, so will leak under vacuum like all dump valves with this design. But as it is recirced, this is not a problem. |
#8 | |
![]() Quote:
Another question, my buddy is running a DSM eagle talon BOV recirculated on his SR swapped 240sx. It has no adjuatment how does this valve work without adjustment? Same type of valve in picture.
![]() Join Date: Sep 2005
It's a bypass valve, works by vacuum.
It should be recirculated. Google how a bov works. From a Highly Tuned Note 4.5!!!
#12 | |
![]() Quote:
HAHA aarrogance is next to godliness |
#13 | |
Most zilvia folks skimp on everything because they believe some 50$ crap from ebay does the same job as a 300$ valve from hks. If you are going to buy it directly from HKS, then it should be genuine, yes. And you should be able to sell it later (it is genuine AND it makes that noise every kid dreams about). It still is a bulky valve with a small outlet, meaning when changing it you are going to need some bigger recircing pipes too. Your choice though. |
#14 | |
![]() ![]() And yes, yes it is! From a Highly Tuned Note 4.5!!!
#15 | |
![]() Join Date: Mar 2012
the more boost they run the better they seal for a start! or is this just your opinions on ALL dump/bov valves are cr@p based on internet myths that people like you keep regurgitating ? So you have fitted and used one of these?, be honest now as I doubt you have because if you had and you fitted it correctly I would like to know why you feel the need to bash on it? running issues? were do you get this idea they are small internally and can't flow? have you even looked at the cross sectional diagram showing its internal diameter and how when the 2nd valve is open its the same size as the ID of the connector? Now look at this as I doubt you ever have http://www.hks-power.co.jp/en/product/blow_off/sqv/ and quit with the internet myths that you have been regurgitating since at least 2008 when I joined the sxoc/zilvia/nicoclub etc If you have any concrete data based on true facts from YOUR OWN experience of the part in question and usage post that FFS! for the record I have tried just about ever valve out there and the ssqv was the only one to date that I had no running issues with Yes you will if on a MAF get a split second of over fuel,and a pop of flame if the exhaust is hot but who don't run a turbo and car and like flames? don't answer that one crusty as I know your opinions ![]() |
#16 | |
#17 | |
I did have the re-circ fitting on another ssqv, the early adjustable version with the eight sided back end, worked fine as it seals perfectly but I always ran vent to atmos, gold triple fin insert is my fav ![]() |
#18 |
Dude, i don't know what happened to you, but seriously ? Piss off.
I know how a double piston valve work, thanks. And i also know 19mm is too small a diameter to get a working recirc at higher boost, WHICH IS EXACTLY WHAT I WROTE. Cunt. |
#19 |
![]() Join Date: Dec 2006
Wow this a lot of overthinking for a BOV. Just buy a Greddy Type-R BOV and be done with it.
#20 | |
,Cunt! really? that would be the thing your mum shaves with a broken bottle, but we don't want the whole world to know that do we ![]() So you haven't used one as I expected and if you had looked at one you would know that the opening is 29mm not 19? and the body of the valve is bigger internally, SO were is your data that these can't flow? you haven't tested one, but I'm sure a large company like HKS would have done endless testing and as it works during testing they then made it and have done for some time but the op asks for advice from people who have used one, and you just wade in with negativity based on what? you haven't used one and just rolled all BOV's into the there crap (again) At least I post an opinion based on using one of these and give the OP some useful advice so what did you bring to the party? was it useful info? |
#21 |
HKS sells a shiny bov for stupid people who like toys that make a woosh sound. the kind of people that slam their car on the ground so it looks cool and ride like crap, the kind of people who prefer the woosh sound of a BOV to a working MAF based engine management. Like... oh i don't know.
You, maybe ? Yup. But hey, this is zilvia i guess. Keep playing with shiny toys making woosh noises. Have fun listening to the sound produced by your "favorite shiny gold insert". Meanwhile, adults are talking about things you don't seem to understand, aka recirculated valves. You know, the kind of thing i have done, and the kind of thing you did not ? |
#22 |
![]() Join Date: Jul 2005
An authentic HKS is a great bypass for non-recirculated setups running stock turbochargers with maf sensors that are placed at a greater than factory distance from the compressor inlet.
That said, if you arn't confused enough already, you shouldn't run one because it lacks the vacuum recirculating action provided by other popular "push type" bypass valves, such as the greddy type-S or HKS race models, which allow the compressor to bypass during idle, and all off throttle positions (instead of only high vacuum off throttle situations) which will keep your turbocharger healthy, more free from wear and tear. Many people do not realize how important it is to have the bypass hang open around idle, recirculated. And always keep as much length between the compressor and maf as possible. |
