Old 03-17-2015, 05:31 PM   #1
Magnoliarichj
Magnoliarichj is an unknown quantity at this point
S13 sr trans in s14
As the title states I have an s13 in an s14. My speedo was reading double and after some searching I foud that I needed to install a s14 vss. So I did and the gear. No my speedo does not work and I have used a new wiring connector on the sensor.
Magnoliarichj is offline   Reply With Quote
Old 03-18-2015, 06:01 AM   #2
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
something is wired wrong on you have a bad speed sensor. which one did you replace ? should be the one on the passenger side of trans at the very rear IIRC. when I put my s13 blacktop in my s14 I had to swap the temp sender and the speed sender due to both reading double than it should.
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 03-23-2015, 08:13 PM   #3
Magnoliarichj
brand new sensor from Nissan. s13 sensor works
Old 03-23-2015, 08:28 PM   #4
cotbu
cotbu's Avatar
Go over your work with a fine toothed comb. It appears it's something you did.
And if you had researched you would have known the vss is chassis/cluster specific and probably learned the thermistor is chassis/cluster specific as well. Just saying
From a Highly Tuned Note 4.5!!!
