Old 08-08-2004, 09:38 AM   #1
nipplepinch666
nipplepinch666 is an unknown quantity at this point
t-25 in s14 ka, max. boost?
what is the maximium boost recommended on the stock injectors for a ka with a t-25 turbo. It seems to be doing well with the 7lbs that I am running now.
nipplepinch666 is offline   Reply With Quote
Old 08-08-2004, 12:25 PM   #2
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
that thing has gotta spool almost instantly.
from what ive been readin 6-7 psi maxes out the 270's on stock pressure, and the 370's are good to 10 or so. im not boosting yet but those are the numbers that i am going with so far.
skatanic28 is offline   Reply With Quote
Old 08-08-2004, 02:15 PM   #3
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
I would say be happy with that and don't push your luck. Unless, you're just curious like me and want to put it to the test meanwhile you have a back up engine ready.
-Juan
240Stilo is offline   Reply With Quote
Old 08-08-2004, 04:55 PM   #4
nipplepinch666
I can hear it start to spool at 1750 rpm's and the bov will go off if i let off the throttle. Does anyone with a t-25 know if 9-10 lbs is safe? i'm running 7, and am running rich it seems. mabye it is my stock fuel curve which is making it run rich at low rpm's.
Old 08-08-2004, 06:24 PM   #5
Mr. Spool
Mr. Spool is an unknown quantity at this point
I was wondering the same thing on stock injectors with my ihi, every body says that the stock injectors max out at 5psi and the 370s at 7psi but they never say with what turbo, I have ran up to 9psi by accident and I was fine. let me know what you come up with.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 08-08-2004, 07:03 PM   #6
orion::S14
orion::S14's Avatar
Stock 270cc injectors cannot do more than 200rwhp safely.
Whether that's 2psi or 15psi from your setup, that's the safe limit.
I'd bet your over that by a little bit with 7psi from a T25...you're just waiting for the day it blows due to a lean condition.
Same goes for you "Mr. Spool"...if it's an IHI T4 or bigger, you're pushing your luck.
Once the injectors go static, they can still supply fuel, but not enough for more than 200rwhp (at stock fuel pressure...).
- Brian
Old 08-08-2004, 08:27 PM   #7
Ricer240sx
Ricer240sx's Avatar
Ricer240sx is an unknown quantity at this point
Send a message via AIM to Ricer240sx Send a message via MSN to Ricer240sx Send a message via Yahoo to Ricer240sx
i will be running a T25 on my ka and i was told that the turbo is efficient up to 15 psi!!! i have 444cc injectors out of a RB26, will thoes support the 15 psi??? so should i ask what hp will they hold???? im hopeing to push 300 hp
00 impreza 2.5rs sedan...dd
00 impreza 2.5rs coupe....EJ255, goin rwd!!
Ricer240sx is offline   Reply With Quote
Old 08-08-2004, 08:41 PM   #8
orion::S14
orion::S14's Avatar
~14psi is the common "max" on an SR.
444cc injectors, stock fuel pressure, and a max of 95% duty cycle will theoretically get you to ~292rwhp safely, if you plug the numbers.
T25 + KA + 15psi will get you to ~270rwhp I'd bet, but probably over 300rwtq...based on "AceInHole"s dynos.
T25 are only good to about ~250rwhp on an SR...it'll get you a little more from the KA, but not much.
- Brian
Old 08-08-2004, 09:03 PM   #9
Mr. Spool
The ihi I have is quite small, smaller than a t25 as far as I know, infact at 4psi there is little to no change over stock, but at 7psi it pulls hard, I keep it lower but due to a boost leak I was running 7 for a while.
96' SE Turbo'd
Old 08-08-2004, 09:18 PM   #10
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
- Brian
I hit 275rwhp and 310tq at 13psi. That's with dangerous ignition timing, though. A boost retard would bring it down quite a bit....
Finally drove my car again today after putting another engine in. I had forgotten how fast the T25 spools.... seemed more instant than my friend's supercharged honda.
AceInHole is offline   Reply With Quote
Old 08-08-2004, 10:21 PM   #11
orion::S14
orion::S14's Avatar
I couldn't recall...I was thinking 255rwhp.
I stand corrected.
Old 08-09-2004, 07:03 PM   #12
Ricer240sx
Ricer240sx's Avatar
i got walbro Fuel pum too lol but i really really want 300hp!!!!!! lol i guess ill have to pick up a 14b or something hehehehe maybe a T3 who knows
