Old 03-20-2015, 07:24 PM   #1
Modify
Modify's Avatar
Modify is an unknown quantity at this point
Weird Acceleration Issue
Hey guys!
So I've recently had troubles with my KA dual cam.
Chronologically, my car had a rough idle and acceleration issues. It lead me to believe my MAF was on its last leg. It finally began to randomly die on me while idling, and the acceleration would completely cut while under load for anywhere from 3-15 seconds. I replaced the MAF and ran into a new problem: my car won't rev past 4k under heavy load(pedal to the floor). If I'm light on accel, it will go through the entire rev range with an issue. The idle is also good.. I did a bunch of reading and found it could be multiple issues. Today, I replaced the underhood fuel filter and the TPS. The TPS is set at .48v. The problem still persists, in the same fashion. Still have a good idle, still won't go past 4k rpm's.
I honestly don't know where to go from here so any input would be greatly appreciated!
Modify is offline   Reply With Quote
