Old 12-11-2004, 03:11 PM   #1
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Modifying H3 bulb to work in place of H3C?
Couldn't find anything in the search... maybe its cus I suck.
But this should probably be archived once the answer is made clear.
S13 Silvia headlights use H3C in several applications... on the Dual Projector housings, its used on the lowbeam and I think the fogs, and on the Triple Projector housing, its used on the fogs as well (thankfully, the low beam is a H1).
Now then, I understand H3 can work in place of H3C with slight modification. I dont want to screw anything up figuring it out, so does anyone have any idea what needs to be done to make it work?
FYI, H3C is only available in Japan, so this is why I would like to clarify this.
Thanks
kazuo is offline   Reply With Quote
Old 12-11-2004, 04:17 PM   #2
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
Car is different but the principle is the same
radhaz is offline   Reply With Quote
Old 12-11-2004, 06:06 PM   #3
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
i got my h3c's from ebay, they have them from time to time... and i think jspec sells them too.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
