Old 07-04-2015, 06:41 PM   #1
Nissan_crazy
Nissan_crazy is an unknown quantity at this point
Megan down pipe touched frame rail(Brand new DP)
I'm having a pretty big fitment issue with my megan down pipe touching the frame rail.I can't even bolt it up because the frame rail is in the way.Has anyone else had this issue with their Megan DP.
My set up is a Red top Megan bottom mount manifold,T28 megan elbow and attempting to install a megan dp.On an s14.Frame rail is straight also.
With my s14sr oem dp I had zero fitment issues.
Did I get a defective DP?
Thanks
Nissan_crazy is offline   Reply With Quote
Old 07-04-2015, 08:17 PM   #2
jr_ss
Are you bolting it up in the correct orientation, because it doesn't sound like it.
Old 07-05-2015, 03:39 PM   #3
Nissan_crazy
Yes for sure I am.If I were off.then it would be either sticking out the wheel well or on top of the transmission.I need roughly another inch of clearance to be away from the frame and have it not hit the frame when the engine twists under load
Thanks for the reply though
Old 07-14-2015, 02:42 AM   #4
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
If it doesn't fit, then try buying another downpipe. I'm using a megan style manifold, megan elbow, ebay downpipe and its super close to the frame rail on my s14 with s13 sr20.
DennisC is offline   Reply With Quote
Old 07-14-2015, 09:33 PM   #5
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Cut, clock, mark, weld, call it a day.
S13 coupe, KA-t
kruked is offline   Reply With Quote
