Old 08-27-2015, 02:21 PM   #1
zac971
zac971's Avatar
zac971 is an unknown quantity at this point
Geomaster knuckle(sandwich)
Zilvia,
Looking for a little feedback. I'm running a geomaster front knuckle on an s14 and I'm not convinced that I've got the full potential out to them. I am thinking that my lca is extended a little too long. The tension rods fits to a point, but I think this is causing a little too much caster and an early lock-out on the control arm:
Full lock to the left - driver side
http://1drv.ms/1WVc0jS
Full lock to the right - driver side
http://1drv.ms/1WVc8zJ
I did a quick measurement of roughly 16" +/- 1/8" from the center of the heim joint (subframe side) to the end of the lca. Also, my wheels do not rub the front of the fender. Before I start taking this all apart again, I am curious what others with similar configurations might be doing.
Inputs appreciated, thanks in advance.
"If you can't fix it with a hammer, you've got an electrical problem"
zac971 is offline   Reply With Quote
Old 08-27-2015, 03:41 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
There are a lot of factors that play into this. Are you running rack offset spacers or is your rack moved forward? Do you know what caster you're running? Have you played with caster at all?
Old 08-27-2015, 03:53 PM   #3
zac971
zac971's Avatar
Are you running rack offset spacers or is your rack moved forward? Yes, driftworks spacers
Do you know what caster you're running? I don't. My caster/camber gauge isn't here yet
Have you played with caster at all? Yep. It's a few degrees positive, but cannot say how much without my gauge
Old 08-28-2015, 07:03 AM   #4
nmingevm
nmingevm is an unknown quantity at this point
nmingevm is offline   Reply With Quote
angle, geomaster, knuckle, steering
