Old 11-19-2015, 09:31 PM   #1
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
PFC/VVTI 1JZ Info
So I'm setting up for some power here over the winter, and am gonna go PowerFC, mainly want to get some info together from some people who have run a D Jetro or L Jetro (doesnt really matter)....
Main info Im looking for:
What injectors are you running with either an OEM rail or rail for OEM mani? How do you like them, got maps to share? What base rail pressure are you running?
How does powerFC handle progressive boost controller duty cycle ramping? Can I map duty cycle through the rpm range?
How are the base maps overall for bone stock swapped 1J? (DP/IC, etc)
Also, I assume theres a MAP sensor already on the block itself? Doesnt look like the full D Jetro kit comes with a map sensor, and if so, what did you use?
Lay it on me.
renegade_ewok is offline   Reply With Quote
Old 11-20-2015, 11:21 AM   #2
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
I have no experience with PFC but I'm interested as well. I found this link while searching:
http://www.paulr33.com/powerfc-faq/powerfc-faq.htm
Hope that helps answer some of those questions.
bmaddock is offline   Reply With Quote
