Old 09-11-2004, 05:33 PM   #1
vegita319
vegita319's Avatar
vegita319 is an unknown quantity at this point
Send a message via AIM to vegita319
Fuel Lines
WTF???? Today i was changning my fuel filter to a z32. I removed the fuel pump fuse and crank the engine. THE ENGINE WOULDN"T STALL. Man and after that i killed it and tried to start the car and it was having trouble start up but if i wait a while it will start slowly get better. Shoot, it never did this before. So i decided to continue and take out the fuel filter anyways and the fuel line connected to the engine release the fuel so im guessing that maybe the engine is storing fuel somehow. Does anyone know why my car wouldn't stall and still allow the car to continue running?
vegita319 is offline   Reply With Quote
Old 09-11-2004, 07:29 PM   #2
projectRDM
projectRDM's Avatar
You have to crank it several times, until it does stall. Usually it takes a good 10 tries, or you can just park the car for an hour with the cap vented.
FORMERLY R240NA
Old 09-12-2004, 07:49 PM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Pull the fuse out while the car is its running. It will turn off in a few seconds if its the right fuse. After install you can turn the key to the ignition on position a few times before starting to get fuel to the rail.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 09-12-2004, 08:55 PM   #4
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
its not that necessary to remove the fuse anyway. fuel still leaks either way.
papershot is offline   Reply With Quote
Old 09-12-2004, 09:34 PM   #5
Andrew Bohan
it's considerably less fuel if you pull the fuse though
Old 09-12-2004, 09:42 PM   #6
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
we do fuel filters where i work, just pull it out and dont be looking in its general direction at the time
black s13 is offline   Reply With Quote
Old 09-12-2004, 11:04 PM   #7
sr240mike
After shutoff I have about 15 psi of fuel pressure. You really dont want that amount of fuel to spray everywhere. Just pull the fuse first it takes 10 seconds.
Old 09-13-2004, 03:34 AM   #8
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
Did mine without pulling the fuse, had a rag ready though, wasnt too much gas. Just be sure everything dries up before you crank the thing on.
evilimport is offline   Reply With Quote
