Old 01-05-2016, 07:17 PM   #1
twest7740
twest7740 is an unknown quantity at this point
s13 Sr20det turbo glowing red hot?
Okay guy's I have been lurking in this thread for almost 2 years now but this issue finally got me to make an account as I cant find anybody with my same issue or someone who has posted a fix, and I kind of want an explanation of what is happening. So my car is an s13 with stock blacktop sr20, Basic swap stuff has been done but nothing other than that, yesterday at the track I made about 10 runs or so and I noticed my car was getting really close to the H, I pulled in and popped the hood to notice the exhaust housing of my turbo was glowing red hot, I am assuming that the turbo being so hot was what caused my cooling system to heat up and alert me of this, I let the car sit for awhile, removed my hood, checked the coolant, all was well, I go back out make I few runs and check it again, and it wasn't glowing, I probably made a good 20 runs after that and only noticed that the turbo got hot one more time, the coolant system did not, I let it cool down and did 1 more run, Figuring that we weren't going to make any more runs for the night I was sitting in a brake stand at maybe 1500rpms, and boom coolant skyrockets back to the H, I leave the car in 1st gear and it idle'd real slow back to the trailer and almost instantly the coolant temp dropped once I was moving, So now my car does have a huge exhaust leak right before the o2 sensor on the turbo outlet, so exhaust was coming into the bay (hence why I removed the hood) since it was leaking before the o2 I was getting a false reading which should have made the car run rich correct? I replaced my spark plugs today and they looked as if my car was running a tad bit lean, my main question is why is my turbo overheating! its confusing the hell out of me.
twest7740 is offline   Reply With Quote
Old 01-05-2016, 07:29 PM   #2
bmxer882x
bmxer882x is an unknown quantity at this point
Check the oil feed, drain, and coolant lines to the turbo. It's both water and oil cooled. I'll bet one of them is clogged.
bmxer882x is offline   Reply With Quote
Old 01-05-2016, 07:40 PM   #3
twest7740
I am going to drain the coolant and unhook the turbo line and run water through it to check. But I just cannot see that being the issue, I would think that if it was clogged that car would be overheating a lot worse than it is.
Old 01-05-2016, 08:25 PM   #4
bmxer882x
I'm thinking it's a oil line messed up. Causing the turbo to overheat which is then boiling your coolant and returning it in the system.
Old 01-05-2016, 09:22 PM   #5
twest7740
I had that in my mind, I just wasn't sure. Thanks for the help I was just looking for more input, What would be the best way to go about cleaning it out and fixing the clog? If I were to blow air through the system I would blow it back into the motor and the issue would just happen again in due time.
Old 01-05-2016, 09:41 PM   #6
bmxer882x
Take off the drain, that way if it does blow sludge through you can collect it.
Old 01-05-2016, 11:02 PM   #7
Sileighty_85
Sileighty_85's Avatar
If your manifold/turbo are glowing red hot then that is not a turbo coolant issue.
Its means your EGT's are really high. Meaning your AFR's are outta wack (Unless you are pushing a lot of power)
So you need to check your AFR's.
I don't think the two issues are completely related, Although High EGT's can cause Engine temps to rise but not to an over heating point as long as you have bigger rad and sufficient airflow.
Thermo might be going bad so that might explain the somewhat random overheating.
ECU only read the O2 sensor when its below 1,500 RPM's, above that its ignored.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-05-2016, 11:09 PM   #8
twest7740
It's a stock sr on 7lbs, nothing should be out of whack all of a sudden, my afr is way out of whack because of the exhaust leak, my wideband was above 17.00 at points once I get the leak fixed (gasket should be here tomorrow) I will be able to monitor it, could the leak cause this to happen? To explain the leak, there is only 1 bolt holding my turbo elbow on right now, the rest back themselves out. Also, I noticed a lot when I was searching that the manifold would get hot for other people, mine is just the turbo.
Old 01-05-2016, 11:22 PM   #9
Kingtal0n
Kingtal0n's Avatar
sounds like high egt due to fuel or timing issue. some possible: bad tune, bad ecu, wrong timing setting, clogged cat, wrong a/f ratio due to bad fuel pump, clogged filter, air leak between maf and compressor.
7psi is not much. if you are glowing with 7psi something is seriously wrong. Did you dyno tune the car? 9-10* off an OEM turbo at 7-10psi is fine when a/f ratio is 12:1, check you are there first, should be around 190rwhp if the engine is stock, compression test 140-150psi, use 93 octane.
tinyurl.com/4l80er
Old 01-05-2016, 11:29 PM   #10
twest7740
The car has never seen a dyno and isn't running a tune, I just set the timing 2 weeks ago, I can't the CAS isn't loose it didn't move so timing has got to be the same, I'm not running a tune for the face that I'm running stock boost, stock everything except for exhaust and a front mount, also the turbo is spooling like normal, holding 7lbs with no leaks, that happened pretty much over night. I know the leak in the exhaust has to have something to do with it since that's the only thing that has happened since last event when it was running fine, also has a 255 fuel pump in it. Car has ran 93 fuel since I put the motor in, The motor is running awesome besides this issue. Not smoking either, only time it smoke that day is when I spun out and it died it spit some black smoke out but it stopped after a few revs
Old 01-06-2016, 01:01 AM   #11
Sileighty_85
the exhaust leak has nothing to do with it.
It is a fact something is wrong if your stock SR setup has a glowing turbo, but not the exhaust leak.
後輪駆動車1番
1986 SR86 - 200ish
Old 01-06-2016, 03:31 AM   #12
Croustibat
Glowing turbo usually means cas is retarded and/or you got a nasty fuel delivery problem (fuel pump, fuel pump wiring, fuel filter are the usual culprits, in that order) .
If you didn't notice it to spool faster yet not getting power, then it is not a timing problem. You already changed the fuel pump for an unknown one, so get a voltmeter and check voltage at the pump for a start.
Old 01-06-2016, 07:34 AM   #13
twest7740
Okay thanks guys I'll check the timing when I get of work and check voltage. And inform this evening, it is just an Isis pump so I wouldn't be surprised if it was bad already, fuel filter is also a brand new z32.
Old 01-07-2016, 01:07 AM   #14
Croustibat
a walbro 255 is usually at the limit of what the stock, very thin and old wiring can provide, so a counterfeit isis one would surely go over the threshold, leading to voltage drop (and not enough fuel pressure / flow).
Very easy to check.If the voltage is ok (which i don't believe, my guess is you will have around 9-10V instead of 14-14.5V), the it probably is the pump.You need a fuel pressure gauge for that, Tee it after the fuel filter, block it under a wiper and go driving. You are supposed to get "boost" + 3bar (45psi) on it (so less than 45psi when under vacuum); if the pump is no good, the pressure will drop at speed on boost and / or at 4000+ rpm
Old 01-07-2016, 06:53 PM   #15
twest7740
Timing is perfect, fuel pressure is 50 + when in boost. Really stumped here.
Old 01-07-2016, 07:21 PM   #16
Sileighty_85
Check for VAC leaks on the turbos intake pipe after the MAFS
後輪駆動車1番
1986 SR86 - 200ish
Old 01-07-2016, 07:40 PM   #17
twest7740
Nope, all is good there one of the first things I checked.
Old 01-08-2016, 07:46 PM   #18
twest7740
Got the exhaust leak fixed today, took it around the block to see the afr it's it's flat lining in boost instantly, super lean. It's about 14.6 when idling. I'm stumped. Side note, thermostat also went out same day (car won't warm up hotter than 140) also when I start the car none of my interior stuff work except for the battery light, give it a rev and everything turns on. Lol WHY ALL AT ONCE
Old 01-09-2016, 09:29 AM   #19
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
In an earlier post you said that you don't have a tune. I would suggest you get one asap.
14.6 when idling is actually a good thing, so no worries there.
In terms of the lights, check the output of the alternator at idle, it should be 14 - 14.5V ( I think ). I think that there is another thread in here concerning the SR alternators not charging at idle ( or something like that ).
SoundEfx is offline   Reply With Quote
Old 01-09-2016, 09:34 AM   #20
twest7740
But I shouldn't need to run a tune when the motor is stock, running stock boost? I feel as if I get a standalone and tune it I will just be putting a band aid over the issue, I'm going to hard wire the fuel pump and check my fpr and maf.
Old 01-09-2016, 10:16 AM   #21
SoundEfx
SoundEfx's Avatar
Sorry, I didn't know this was a stock setup, so you're right, you shouldn't need a tune.
Old 01-09-2016, 10:39 AM   #22
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
don't rule out a clogged coolant/oil feed line.
I have personally seen the coolant feed fittings clogged shut on customer cars, where they ran straight water without water wetter or some other kind of additive.
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 01-09-2016, 10:45 AM   #23
twest7740
Yes I'm going to also check the turbo lines, but that won't solve my lean issue.
Old 01-11-2016, 01:46 PM   #24
Kingtal0n
Kingtal0n's Avatar
Fueling is
maf -> ecu -> injector
So, not a whole lot to go wrong there. Either somethin with the maf, ecu or injectors, or the fuel provided to the injector. You might have the wrong injectors in the engine or a bad ecu, or a bad wideband, or the wrong maf, etc use your diagnostic skills
If it was my engine, and I just bought it from you, to solve the issue I would do this:
0. compression test
1. tune up (plugs, oil, fuel filter, air filter)
2. boost leak test (a real one with 15psi or more into the entire plumbing)
3. replace ecu, maf, fuel pump, or injectors as necessary
tinyurl.com/4l80er
Old 03-15-2016, 03:45 AM   #25
jppierre
jppierre's Avatar
jppierre is an unknown quantity at this point
Sorry to revive this but i have a similar issue and im out of ideas, my exhuast manifold glows red hot just by driving in the freeway and my car overheats exactly after 3 miles of driving on the freeway at 70mph at around 3k-4k rpm, i let fo of the gas and water gauge shoots up higher and as soon as i get back on it my water gauge goes down and starts climing back up slowly.. I pulled to the side and pop the hood while the gauge still on overheating and my exhaust is glowing red hot and smells like burnt oil a bit but no smoke ad its very hot under the hood, i have a aftermarket radiator cap that tells me the temperature and its right around 150f which is perfect, but car is still over heating.. Car runs perfect with no issues besides lots of backfire , as soon as i got home i removed spark plugs and they are almost clean like new, the eletrode thing still super white and the flat round part is all black and the tip is barely burnt and a bit white... Running lean for sure but why?! The engine is all stock
jppierre is offline   Reply With Quote
Old 03-15-2016, 04:02 AM   #26
Croustibat
Same cause = same consequences, retarded timing or poor fuel delivery, so check these. If you cannot, bring the car to someone who can.
Better do it fast because things that make a turbo glow tend to melt pistons, too, and glowing turbos die quickly.
Old 03-15-2016, 04:04 AM   #27
Tyler_240
Tyler_240 is an unknown quantity at this point
Manifold glowing red hot means your temps are in excess of 1500 degrees, like others posted in this thread, typically means your timing is jacked and its retarded. If your timing is off, a trip around the block could cause the EGTs to skyrocket.
What engine? Check your distributer/CAS, did this just start happening or did you buy the car this way?
Tyler_240 is offline   Reply With Quote
Old 03-15-2016, 08:22 AM   #28
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
If your AFR are past 17 in boost after you fixed the exhaust leak, that's your problem. You tested the fuel pressure to be over 50psi when it was flat lining? If so check the MAF and injectors. Even your TPS. Maybe your ECU is staying in closed loop for some reason.
Crazyced is offline   Reply With Quote
Old 03-15-2016, 08:54 AM   #29
twest7740
I fixed my issue awhile ago, this is an old thread. I had to replace the maf, knock sensor, coolant temp sensor, hard wired the fuel pump, put in a aftermarket fpr and it runs good now.
