![]() Ok I don't have a 240sx yet, but I do plan on getting one in the very near future (hopefully I can find a decent one once I have all the funds). But in the meantime I have been trying to figure out what mods I plan on doing. I'm trying to think of exterior and interior mods first, because I will probably stick with the ka for a while. I want to rebuild it, but I still want the ka for learning.
But that gets me to this question. Is there a wide body kit out there that does not have to be riveted? I really hate the look of the rivets, it doesn't look good in my opinion. Same with the obvious edge of the fender kit itself. What I want to do is put it on so there are zero rivets, and make it flush with the body. Do they make something like this? Because I can't find any that don't have rivets and/or flush with the car body. I've thought about putting bondo on the edges of the kit so that I can possibly make my own incline to match up the surfaces. Would that work, or is it optimistic? Basically what I want is for it to look somewhat OEM, just wide body. So to the untrained eye, people wouldn't even think twice if it was aftermarket or not. Because I love the idea of wide body, but I really hate the tacky (IMO) rivets and uneven body surfaces. It looks unfinished to me. |
Yeah it's called $1,000's in paint and body work. What you are wanting to do is a molded body kit. This takes skill and proper materials. No, bondo will not do.
You will have to cut and re-weld the arches. Properly seal them from moisture. Prep the body surface where you will bond the FRP panel to the OEM metal. You will need panel bond, short strand fiberglass fillers, a good quality light weight filler, full set of sanding blocks, various grit sand papers, and a good amount of experience. Then add your primers and paint. Also you will want to start with a good quality over fender like charge speed which run $650 or so.
MRP Manufacturing |
![]() Join Date: Jun 2003
Trader Rating: (130)
vertex ridge /thread
http://www.vertex-usa.com/catalog/RI...DY-SYSTEM.html ![]() http://www.vertex-usa.com/catalog/RI...DY-SYSTEM.html ![]() roughly $3k for the kit, plus shipping, plus labor/install. |
#4 | |
If I ever do plan on trying anything like that, I'd probably try it on a junk chassis or work in a body shop. Thanks for the reply tho, are you experienced with that kinda thing? Because I can't really find much information online about this topic. Maybe I'm not searching the right thing, or not hard enough. |
I've done my fair share of body work/fiberglass repair and I would be a bit hesitant to do it without professional guidance....which I have been fortunate enough to find.
MRP Manufacturing |
#6 | |
Yeah it'd be nice if I knew someone that could really teach me, because I can only learn so much from books and research. I'm a hands-on person, and I usually fail pretty bad at first but I'm pretty quick to learn what is right and what is wrong. Maybe if I find someone in the future lol
#10 | |
Like KAT-PWR said, molding a body kit properly to car will take a lot of time, money, and skill. I would not recomend someone to do it that has zero experience with body work, or even some experience with body work. Bottom line is, you are not going to be able to do the work yourself and have it not come out like crap. Most (if not all) kits need to be fitted properly out of the box. I know starting out you want to do most of the work on your own car. I know the feels, but somethings (like body work) I would just let someone that has the experience do it. Good luck on the S14! |
![]() Join Date: Oct 2011
Molding on the over's isn't hard, as long as you have patience and can sand you can do it with time. Take a look at this build, page 6 and 7, you will see one technique used- however it can be done in different ways:
http://zilvia.net/f/showthread.php?t=447170&page=6
S13 Silvia Lip's f/s :www.codycasale.com
#13 | |
MRP Manufacturing |
#14 | |
Making a poor fitting panel fit well, yes I agree - its a pain in the ass. But if you start with a decent fitting panel then the rest should be fairly straight forward. Pinholes and waves, can be difficult to remove- but most paint shops can help with that.
#15 |
![]() Join Date: May 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
i had my fenders molded on it looks really clean but the down fall i had was the body kept on flexing and cracked the paint on the overs. Look in the wheel fitment thread i posted some pictures of it in there. But be prepared to spend $$$ like KAT- PWR said the fender needs to be cut, welded, sealed properly. I also had the the gap between the overfenders and cut metal completly sealed so it looks OEM when you look under it.
Tags |
240 240sx, flush, how to, oem, wide body |
