Old 08-02-2016, 04:49 PM   #1
Domo757
Domo757 is an unknown quantity at this point
Windshield wipers not working
I replaced the switch, wiper amp and motor. All my fuses are good I also have voltage and continuity through the whole system and nothing is working. Help me i need an inspection.
Domo757 is offline   Reply With Quote
Old 08-02-2016, 08:48 PM   #2
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Def switch contact points
Old 08-02-2016, 08:59 PM   #3
Domo757
What do you mean?
Old 08-02-2016, 09:17 PM   #4
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Maybe the wiper linkage is seized up.
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 08-03-2016, 06:02 AM   #5
dustin_rps13
dustin_rps13 is an unknown quantity at this point
By switch contact point, he's talking about inside the wiper combination switch. These are known to be faulty in there old age and they get progressively worse as time goes on. Usually taking them apart and cleaning them with the proper cleaner, will make them work again. If that doesn't work, you may need to have new solder points put in.
Could also be the wiper linkage, but it's not too often that these seize up, unless the little plastic bushing has worn out.
I HAVE A BEARD, THEREFORE....F@#% YOU!
dustin_rps13 is offline   Reply With Quote
Old 08-03-2016, 06:29 AM   #6
kruked
Trader Rating: (37)
...the very first thing that the OP mentioned was that he replaced the switch
S13 coupe, KA-t
Old 08-03-2016, 06:31 AM   #7
dustin_rps13
Sorry, should have asked if he replaced with a NEW switch, or if he just bought a used one. Could still be an issue if he bought a used switch.
Old 08-03-2016, 07:44 AM   #8
jedi03
try powering the wipers directly...
Old 08-03-2016, 08:34 AM   #9
Domo757
I got brand new parts. I disconnected the motor from the wiper linkage to see if it moves and i have nothing. Im going to try powering the wipers directly. Thanks for all the help guys im going to let you know what happens.
Old 08-03-2016, 08:49 AM   #10
Domo757
I FIXED IT!!!! After looking at the schematics for the wiper system i found put the wiper motor has a case ground lol
