Old 09-16-2004, 07:47 PM   #1
180SXtc
180SXtc is an unknown quantity at this point
Send a message via AIM to 180SXtc
SR hesitation or bogging under H.T
Here is the deal and problem. Today is the first day for me to street my sr and it runs great however. When I roll into throttle im smooth all the way to redline (obviously not as much power this way), However when I get into the throttle hard like 50%+ or more esp. in first and second I get this bogging or hesitation followed with some pops and backfires. My assumption is fuel system I could be way off I know and i also know that fuel is very vast assumption. My question is has anyone had any experience with something like this or could anyone give me some specific symptoms to look for. Thanks
Tony
91' hatch
RedHead SR20DET
Apex-i N1 Cat Back
HKS Downpipe
Blitz LM FMIC
Sr20detperf Hot Pipe
HKS SSQ
Apex-i Intake
Rays 77w 17x8
Eibach sportline
Tokico Illumina
180SXtc is offline   Reply With Quote
Old 09-16-2004, 09:26 PM   #2
monkeyspeed
monkeyspeed is an unknown quantity at this point
i have the same problem....i changed the fuel filter and it helped, but it stil does it...i think it's the timing as i have checked everything else...
monkeyspeed is offline   Reply With Quote
Old 09-16-2004, 10:31 PM   #3
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
read and search there are several people who are having this problem. I am not sure it the solution was solved but the threads are there.
silviasichigo is offline   Reply With Quote
Old 09-16-2004, 10:39 PM   #4
bdeisle
bdeisle is an unknown quantity at this point
i had the same problem for a sec. when i changed an blow for IC piping and it was just a small boost leak.
bdeisle is offline   Reply With Quote
Old 09-16-2004, 11:56 PM   #5
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
could be you need a fuel pump, or your turbo nuts could be loose and that causes it also, other then that check all your vaccuum lines cuz mine was eaten up by my manifold the other day and i was bogging after a certain amount of boost also
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 09-17-2004, 12:01 AM   #6
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
Yep check gasket leaks. Check timing. Get an aftermarket fuel pump (i didn't see that on your list)
Turbo piping, Intakes and More:
http://www.pipingpro.com
Pepperoni is offline   Reply With Quote
Old 09-17-2004, 09:50 AM   #7
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Could be tps also. If it only studders for a few seconds after you floor the throttle, then takes off like no problems, that could be a tps issue. Other then that timing, spark plugs maybe?
autobahNESSA is offline   Reply With Quote
Old 09-25-2004, 09:36 AM   #8
180SXtc
Problem Fixed.... I pulled my plugs only to find out that the ground strap on cylinder 4s plug was well not there replaced plugs runs great thanks guys..
Tony
91' hatch
RedHead SR20DET
Apex-i N1 Cat Back
HKS Downpipe
Blitz LM FMIC
HKS SSQ
Apex-i Intake
Rays 77w 17x8
Eibach sportline
Tokico Illumina
