Old 09-21-2004, 08:32 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
fuel pump, which one
I am trying to figure out what type of fuel pump my car has. I have no idea how to tell which one I have, I believe it to be a 300tt pump, how would I tell. thanks.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 09-21-2004, 10:28 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
what are you basing your guess on?
Old 09-22-2004, 03:20 PM   #3
Mr. Spool
there appears to be a fuel gauge hooked up in the engine bay to the fuel line, the car also has a turbo kit hooked up and was suppossedly set up for 12 pounds of boost but was only running 4. what other info would be ussful. thanks.
96' SE Turbo'd
Old 09-22-2004, 03:29 PM   #4
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
pull the pump out of the tank and take a picture of it. how about that?
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 09-22-2004, 07:33 PM   #5
Mr. Spool
got the pump out, what should it look at.
sorry not at but like, what should it look like, are there differences that I should be aware of.
96' SE Turbo'd
Old 09-22-2004, 10:34 PM   #6
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
stock is small and gold and says "denso" on the side.
300zx should have additional wiring since it has that "high" and "low" setting thing.
andrave is offline   Reply With Quote
Old 09-23-2004, 07:24 AM   #7
Mr. Spool
this pump was able to plug into the stock wiring harness on an 89 240. the pump to me at least appears huge, it is silver with floaters and such. it has 4 wires coming into it as well.
96' SE Turbo'd
Old 09-24-2004, 11:41 AM   #8
andrave
andrave's Avatar
is there any lettering anywhere on it?
how does the rubber isolator compare to a stock 240 one?
the walbro kit comes with a new screen and a different isolator.
Old 09-24-2004, 09:50 PM   #9
Mr. Spool
I finaly found the bosch name on it. I cant quite make out the part number becouse it is covered by part of the fuel pump.
96' SE Turbo'd
