![]() Join Date: May 2008
![]() ![]() ![]() Feedback Score: 1 reviews
Tire Killing Machine z32 drift car
Finally got a Daily here it is ![]() Time has come to put the Z under the knife and make it a real drift car. TRYING to make it formula d pro am Atlanta this year, time is ticking and I got a lot of work to do so we shall see what happens. Current car mods, blah blah all the regular stuff, the lastest cool thing was a Reinforced sub frame w bushings from PBM, solid diff bushings, project mu ebrake shoes (which work awesome hydros are laaame) and urethane bushings for the rear uprights. ![]() Current plans- VH V8 swap, FD spec roll cage and some small stuff along the way. ![]() Current Progress- gutting interior, stitch welding, Planning out cage, Pulling out gay ass VG engine, Custom Fender Braces, Port matching ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Header flanges ![]() Clearance ![]() Engine mount base plates ![]() Copying the plate ( why do you ask?) because I have the ability to and when I’m done I can have a plate for the ¼ of the price. ![]() As soon as I finish making the plate I’ll put the engine and trans in and start making the motor mounts, headers, and figure out oil pan clearance.
![]() Join Date: Jun 2008
thats rad to see a z32, quick question though. i can't see the pic so i don't know how severe it is...but doesnt formula d not allow modded/reinforced sub frames? i doubt the same rule applies to pro am but it's worth a read...GOOD LUCK!!!!!
as far as I know its not really modded (rear at least) (cut up or anything) BUT they changed that with the huge v8 fad, they now allow it.
Hey Mongooze,
I seen you a while back at a drift event in Palm Beach. You did your damn thing. I even think you had a NA engine at the time. Keep up the good work with the Z32 |
#9 | |
yessir! na as fuck! I blew up that night, I didnt just spin a bearing, I grenaded it. theres another one coming march 11 same place, full track this time!
Plates done! That was fun…
cut ![]() bolted ![]() welded ![]() shaved ![]() Final welded ![]() Machined ![]() ![]() ![]() Box O bends 1 5/8 Universal header kit ![]() Paint ![]() Port matched exhaust manifolds ![]() ![]() In the hole. ![]() Next up is well everything lol cross member/oil pan modify, headers,/exhaust, mounts, hood, wiring etc.
#16 |
![]() ![]() somehow the hood actually clears, all I did was remove some of the inner skin, no shitty hood scoop required. still have alot to do but this is more or less on how it will be. ![]()
#18 |
Had some time in the daylight to snap some pics lol usually work at it at night so I was never able to take some shots.
![]() ![]() ![]() ![]() Had some paparazzi too ![]() ![]() working on the motor mounts ![]() Helped a friend do some door bars on my downtime. ![]() ![]() ![]()
#19 |
![]() Join Date: Nov 2005
This is cool man! I love to see Z32 drifting!
#22 |
What’s new?!
Hacked up k member ![]() Motor mounts ![]() ![]() Collectors ![]() Header work starting now. Sneaky peak at angle n stuff ![]() ![]() ![]() ![]() ![]() Im going to redo that lower pipe that hangs all low, I don’t like the way it looks lol that’s it for now, headers are mocked up just need to finish em, then figure out my other million clearance issues.
![]() Last edited by Mongooze; 04-02-2011 at 07:55 PM.. |
#24 |
you can if you try, i didnt know shit 2 years ago, took a welding class, bought metal and stated cutting shit up, use alot of pics of other peoples stuff for reference. maybe i have a mind to figure out how to piece things together too though, i played with legos alot as a kid lol.
im still learning, those are my first headers.
#25 |
im guessing you used 6010 welding rods for your motor mounts and headers? Awesome car so far man, Fabricating parts takes experience and patience! Im am going to respect you soooooooo much more for putting your car together with a buzz box! represent!
#30 |
update tyyme, update tyyymeee!!!
Im changing some things around, I'm raising the motor and pushing it back some more, I'm redoing the motor mounts and headers, the motor sat too far down and too far forward to my liking, if I'm gonna do it I'm gonna do it right. but in the meantime the car is going somewhere for something..... ![]()
