Old 01-04-2010, 02:19 PM   #1
headup240
headup240 has a little shameless behavior in the past
Send a message via AIM to headup240
Running super rich. ecu code 12.
I swapped my motor out of my coupe into my hatch. I daily drove it for 2 weeks fine until the brakes got really bad and starter quit. So I just decided to finish my CA swap. I finished it and I took the battery, fuel pump, and maf pigtail. I just recently decided to finish the hatch so I put in a battery, fuel pump and saudered in a new pigtail. I go to start it up and It runs really rich and idles rough. I checked the ecu and it throws code 12 which is the air flow sensor. I've tried three different mafs and a different ecu. Still no luck. The connection to the maf is good and is getting a signal. Any suggesstions? Wire the maf straight to the ECU? and if so what to do with the sheilded wire? Thanks.
headup240 is offline   Reply With Quote
Old 01-05-2010, 10:10 PM   #2
killbillsnj
killbillsnj is an unknown quantity at this point
Send a message via AIM to killbillsnj
sounds like you wired the Maf wrong what maf did you put in
check this they have good diagrams for maf wiring
SR20DET Swap Engine Harness Wiring Diagram Guide SR SR20
killbillsnj is offline   Reply With Quote
Old 09-09-2016, 06:11 PM   #3
erik240sx
erik240sx's Avatar
erik240sx is an unknown quantity at this point
did you find an solution?
erik240sx is offline   Reply With Quote
