Old 12-22-2017, 10:55 PM   #1
wolf904
wolf904's Avatar
wolf904 is an unknown quantity at this point
HUGE storage clean out - sr20,GTR,jdm, tial, ikeya formula lca, z brakes, etc. LOOK
-Located in Jacksonville, FL (North East Florida)
-I can drive to meet if you're buying multiple items, buying expensive items, or
paying gas money.
-Pickup is preferred.
-Shipping is available for most items
-Contact: PM or (904) 214 2424 text anytime.
I have a ton of random miscellaneous parts I've gathered through multiple cars throughout the years. Will try to sell on here first before I post up for the locals to stab at.
- PAIR of R34 GTR wheel center caps. $60 obo!!!!!! NEED GONE
20171128_112928 by Gabe Esquivias, on Flickr
20171128_112939 by Gabe Esquivias, on Flickr
- BLITZ tuned sr20det ecu. Believe its just a safer map for turned up boost sr's using a stock setup with bolt ons. Worked good on my SR. $200 or fair offer
20171128_113452 by Gabe Esquivias, on Flickr
20171128_113508 by Gabe Esquivias, on Flickr
- AEROMOTIVE Tsunami fuel pump , and aeromotive fuel filter. Comes with AN Fittings with pushlock lines. Enough lines to do an entire s14 front to rear. External fuel pump ,was pulled from my car in good working condition. The fuel pump alone is like 350 new I think, I will sell lines, fuel filter, and pump with mounting clamps all together for $200.
20171130_132903 by Gabe Esquivias, on Flickr
20171130_132806 by Gabe Esquivias, on Flickr
- IKEYA formula ADJUSTABLE lower control arms. Heim joints instead of bushings, and beefy balljoints with some roll center correction built in I believe. $275 obo for these, fairly rare and honestly a super cool part.comes with hardware also
20171128_131438 by Gabe Esquivias, on Flickr
20171128_131459 by Gabe Esquivias, on Flickr
- Japanese Real Carbon FET Rear strut bar. I specifically know this will work for s13 hatch since thats what i pulled it off of. $80 obo.
20171130_133827 by Gabe Esquivias, on Flickr
20171130_133830 by Gabe Esquivias, on Flickr
- ARC front sway bar with bushings brackets and spherical end links. $100
20171130_133153 by Gabe Esquivias, on Flickr
20171130_133145 by Gabe Esquivias, on Flickr
- RB25/20 Cast manifold. one broken stud but easy fix with a easy out. $30
20171130_131942 by Gabe Esquivias, on Flickr
-Sr/Ka manual transmission, no bellhousings, however this was a good trans, wire wheel and bellhousings would probably have it fine, or just use it for pieces. $40
20171130_133346 by Gabe Esquivias, on Flickr
-RB25DET S2 AC COMPRESSOR, PULLEY AND BRACKET. ALSO HAS FITTINGS. $80
- S13 and S14 AC compressors. have high and low pressure lines, and some condensors as well. make offer on whatever you need.
20171130_132457 by Gabe Esquivias, on Flickr
20171130_133716 by Gabe Esquivias, on Flickr
- S chassis' sway bars front and rear. $20 a piece.
20171130_133932 by Gabe Esquivias, on Flickr
- S14 White cluster in unknown condition. $25
20171130_133218 by Gabe Esquivias, on Flickr
- Cast log mani for Sr20 i believe t3 and t4 flange, have a top mount garret t3 turbo and wastegate i can include with it all. I have no idea what any of it is, turbo doesnt really feel like it has noticeable play, could be fine, $150 should be worth the risk for a setup that could make mid to high 300s and never crack a runner.
20171130_131744 by Gabe Esquivias, on Flickr
20171130_131818 by Gabe Esquivias, on Flickr
20171130_131829 by Gabe Esquivias, on Flickr
- SR20 and I believe KA metal fan shroud for radiator and dual efans with some wiring. Perfect for you guys wanting to make room in your engine bays and run efans, the shroud is what makes it efficient. $100 for these or close offer.
20171130_133631 by Gabe Esquivias, on Flickr
- Resealed, known good working sr20det transmission. no grinds no noises. the issue is there a s13 non abs japanese driveshaft stuck in it. these driveshafts dont have the rubber coupler by the yoke which is a common failure point. I will sell it all together for $100. without the bellhousing I will take $60. This could be a easy fix. I paid $80 for the driveshaft from a friend who brought it back with his silvia and never once ran it, and $100 for the transmission as a KA trans before I put my own sr bellhousing on it. just taking up space. Is probably a easy fix.
20171130_134022 by Gabe Esquivias, on Flickr
20171130_134027 by Gabe Esquivias, on Flickr
- S13 powersteering rack with tie rods. Didn't leak in the short period it was on the car however I didnt drive it much, it just had fluid in the ps reservoir. I only removed it because I had a new one for my car. $50 for this.
20171130_134335 by Gabe Esquivias, on Flickr
- RB25DET (s2 if it matters) flywheel oem. $30
20171130_132411 by Gabe Esquivias, on Flickr
- 2 OEM sr20det Flywheels. $20
20171130_132328 by Gabe Esquivias, on Flickr
- S13 sr20det random stuff. throttle body, water pump pulley, shifter boot metal ring , intake, water neck. pm offers on what you want
20171130_132637 by Gabe Esquivias, on Flickr
- S13 Sr20det blacktop valve cover. fine condition, perfect for a spare to powdercoat. $50. Don't mind keeping this, just figure id post up incase someone wants
20171128_125955 by Gabe Esquivias, on Flickr
20171128_130011 by Gabe Esquivias, on Flickr
- OEM s13 KA24DE Distributor cover. Pretty cool piece you don't see often $30
20171128_114057 by Gabe Esquivias, on Flickr
20171128_114108 by Gabe Esquivias, on Flickr
- Random s chassis steering wheel hub. I have the rubber surround for it just wasn't pictured. $ 20
20171128_114023 by Gabe Esquivias, on Flickr
- Older HKS SSQV $20
20171128_114038 by Gabe Esquivias, on Flickr
20171128_114046 by Gabe Esquivias, on Flickr
- OEM s14 calipers in good working condition. No brackets or boots, but thread fine and come with lines. $40
20171128_113752 by Gabe Esquivias, on Flickr
20171128_114004 by Gabe Esquivias, on Flickr
- S14 Ebrake cables, one left one right and one extra forgot which of. $40 for a pair, $20 for the extra one obo.
20171128_113657 by Gabe Esquivias, on Flickr
wolf904 is offline   Reply With Quote
Old 12-23-2017, 01:25 AM   #2
je_decoy
Trader Rating: (33)
je_decoy is an unknown quantity at this point
Feedback Score: 33 reviews
bump up txt sent
je_decoy is offline   Reply With Quote
Old 12-23-2017, 09:23 AM   #3
carcrazee
carcrazee's Avatar
carcrazee is an unknown quantity at this point
wow my old pignose lip, I know where u got that from haha, bump for you
carcrazee is offline   Reply With Quote
Old 12-23-2017, 09:24 AM   #4
wolf904
wolf904's Avatar
Originally Posted by je_decoy View Post
bump up txt sent
All texts responded too.
Lets keep it moving! Trying to ship out more parts today. Keep texting me
Old 12-24-2017, 11:37 AM   #5
wolf904
wolf904's Avatar
BOV sold, speed sensor pending now! Who wants this pignose lip? ARC swaybar and rear strut bar also currently pending.
Also I forgot I have TEIN 350z inner tie rods, and clean s14 door panels confetti pattern if anyone wants!!!!!!
Old 12-24-2017, 12:24 PM   #6
Po_31
Po_31's Avatar
Trader Rating: (28)
Feedback Score: 28 reviews
If the speed sensor doesn't sell I'll take
Old 12-24-2017, 12:31 PM   #7
wolf904
wolf904's Avatar
If I dont hear back from him or if he doesnt paypal me soon Ill pm you.
Old 12-24-2017, 01:53 PM   #8
slow.s13
slow.s13's Avatar
slow.s13 is an unknown quantity at this point
that was me that texted u yesterday about the pig nose lip lol lemme know how much shipping will be brotha. merry christmas!
slow.s13 is offline   Reply With Quote
Old 12-24-2017, 04:58 PM   #9
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
I want the trans/driveshaft and the valve cover. Any idea how to ship said items?
sidewaysil80 is offline   Reply With Quote
Old 12-24-2017, 08:02 PM   #10
wolf904
wolf904's Avatar
I can get a UPS quote but it probably wont be cheap?
Old 12-24-2017, 08:19 PM   #11
wolf904
wolf904's Avatar
BOV, LCA'S, and Speed sensor are all accounted for and getting priority shipped out tomorrow/tuesday. Anyone else want to place some orders so I can get their items shipped out same day? PM me!
Old 12-25-2017, 02:54 AM   #12
red_240
red_240 is an unknown quantity at this point
Any idea if any of the high pressure AC lines is from a 97-98 240sx?
red_240 is offline   Reply With Quote
Old 12-26-2017, 04:12 PM   #13
wolf904
wolf904's Avatar
I can check this week.
S14 LCA, Speed sensor, and BOV are SOLD.
Old 12-27-2017, 11:13 AM   #14
wolf904
wolf904's Avatar
Ikeya toe arms sold.
Adjustable FLCA still available. All other parts still available
Old 12-28-2017, 06:23 AM   #15
Mr.slipngrip
Mr.slipngrip is an unknown quantity at this point
Ill take the momo hub shipped to 32807.
Mr.slipngrip is offline   Reply With Quote
Old 12-28-2017, 09:43 AM   #16
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
that carbon strut bar is a FET BAR really cool!
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 12-28-2017, 09:18 PM   #17
wolf904
wolf904's Avatar
Check PM!!!!!!!!!!
Any more info? Might keep the shit
Old 12-31-2017, 11:14 AM   #18
wolf904
wolf904's Avatar
bump to the top, pignose lip is pending locally, momo hub is pending as well.
Z brakes and other parts still available
Old 12-31-2017, 06:00 PM   #19
signal240sx
signal240sx is an unknown quantity at this point
Darn...I pmed u while back on lip.let me know if sale falls thru please
Sent from my GT-P5113 using Tapatalk
signal240sx is offline   Reply With Quote
Old 01-01-2018, 02:19 PM   #20
wolf904
wolf904's Avatar
Lip is sold, z brakes are sold, lets keep it moving
Old 01-01-2018, 11:08 PM   #21
izzyou22
izzyou22's Avatar
izzyou22 is an unknown quantity at this point
pig nose lip shipped to 94565?
izzyou22 is offline   Reply With Quote
Old 01-02-2018, 12:37 AM   #22
junkfoodie
junkfoodie is an unknown quantity at this point
Want the rear strut bar if still available. need it shipped to CA, 94566
junkfoodie is offline   Reply With Quote
Old 01-02-2018, 08:16 AM   #23
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
PMd in regards to the HVAC lines.
RalliartRsX is offline   Reply With Quote
Old 01-02-2018, 08:46 AM   #24
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Is the S14 gauge cluster for zenki or kouki?
afishysilvia is offline   Reply With Quote
Old 01-02-2018, 09:41 AM   #25
wolf904
wolf904's Avatar
Still have the FET carbon bar, shoot me a text!!!!!!!
shoot me a text and ill find the lines
unsure, just know its white face, shoot me a text
Old 01-02-2018, 01:42 PM   #26
nism014
nism014 is an unknown quantity at this point
got the IACV?
nism014 is offline   Reply With Quote
Old 01-02-2018, 02:43 PM   #27
Fitelite240
Fitelite240 is on a distinguished road
Is the fuel pump set up e85 compatible?
Fitelite240 is offline   Reply With Quote
Old 01-03-2018, 02:04 AM   #28
red_240
If one of those high pressure AC lines is from a 97-98 I’ll take it!
Old 01-03-2018, 02:14 AM   #29
volgapower
volgapower's Avatar
volgapower is an unknown quantity at this point
OEM silvia front knuckles only needed for 5 lug bearings. i could not find in list, are those available?
volgapower is offline   Reply With Quote
Old 01-04-2018, 11:03 AM   #30
wolf904
wolf904's Avatar
Hey I just updated the FS ad to reflect what is still available ! Please pm me I want to get everything sold and out of my storage unit.
If someone buys both transmissions Ill cut a sweet deal with them and the driveshaft!
Also want sr turbo setup gone!
if you know anyone who needs 34 gtr caps plz send my way, and still got these ikeya FLCA too!!
