Old 01-09-2017, 09:35 AM   #1
Cmazda
Cmazda is an unknown quantity at this point
FS/FT 1995 ls1 swapped 240sx
Hello, Im testing the waters with my 95 240sx.210,xxx miles on chassis. I'm interested in trades or cash and trades just let me know what you have. Trade value 10k. contact through text or through thread 623-313-0850.
Cons of the vehicle:
There are no gauges in the car just a MAX engine vitals digital meter(volts,oil pressure,water temp)
2nd gear is broken from previous owner (engages but makes noise)
tires rub a little in the inner fenders
trunk is cut
no door windows doors are cut (to fit cage)
Pros of the vehicle:
Clean tittle
Formula D spec cage
5 lug conversion
Essentric lockouts
Adjustable tow rods Godspeed v2 low angle
Adjustable RUCAs Godspeed v2
MAX subframe risers
MAX solid diff bushings
Welded diff
Adjustable tension rods
MAX steering rack essentric bushings
K sport coilovers
Cowl spacers 2 inch on front
Nrg quick release
Grip royal steering wheel
No interior except dash and seats
Morison switch panel with push to start
Master power switch at right cowel just below the windshield
Brand new windshield
Sikky MFG swap kit - v3 aluminum oil pan, motor mounts,trans mount,remote oil filter,
Engine
Ls1 from 2001 corvette
70k miles on engine
Ls6 intake
Long tube headers 1 5/8
Optimized tune by frost
Mishimoto radiator and dual fan setup fans turn on at 195 never over heats
MAX engine vitals digital meter (volts, oil pressure, water temp)
Flowmaster exhaust
Transmission
T56 from 99 camaro ss
80k miles on trans
Pro 5.0 shifter
Scoggin dickey ls7 clutch kit
Drive shaft shop steel drive shaft
On mb battles 17x9.5 5x114.3
Has z32 brake conversion
Cmazda is offline   Reply With Quote
Old 01-19-2017, 08:56 AM   #2
Cmazda
bump, what website do you guys use to upload bigger pictures?
Old 01-19-2017, 09:00 AM   #3
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
try photo bucket
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 01-19-2017, 09:05 AM   #4
Cmazda
I did and thats the biggest I can make the photo, its not even worth trying to post the rest if they are that small lol.
Old 01-19-2017, 12:45 PM   #5
shortyman4065
shortyman4065 is an unknown quantity at this point
you have to make sure youre using the IMG link under the photo in photobucket
shortyman4065 is offline   Reply With Quote
Old 01-20-2017, 11:24 PM   #6
zebani
zebani is an unknown quantity at this point
if that doesn't work try www.imgur.com
zebani is offline   Reply With Quote
Old 01-20-2017, 11:56 PM   #7
Philthese93
Philthese93's Avatar
Philthese93 is an unknown quantity at this point
+1 for imgur. You don't need an account either.
Philthese93 is offline   Reply With Quote
Old 01-22-2017, 01:03 PM   #8
COF
COF is an unknown quantity at this point
More pics?
COF is offline   Reply With Quote
