Old 10-08-2004, 06:10 PM   #1
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
SR SR woes. Rapid ticking under valve cover.
About 2 weeks after replacing a failed injector Im getting this loud rapid tick from under the valve cover. The car has been hard to start in the mornings as well. The sound starts once the car starts to get warm and when it is warm. For a few days it went away but now it just getting worse and worse. I have changed the oil twice since the failed injector flooded the cylinder and pulled the valve cover to see if anything looked wrong but nothing seemed bad. Today I looked down at the boost gauge and at idle it was only reading 10 in/hg instead of the 18-20 it normally reads.
The car is still running quite strong though so I am puzzled as to what it is. It sounds bad though. Any help would be greatly appreciated.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 10-08-2004, 11:24 PM   #2
97SilviaRB
97SilviaRB is an unknown quantity at this point
wheres the video?
97SilviaRB is offline   Reply With Quote
Old 10-09-2004, 09:25 AM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Try changing the oil again, but use 20W 50 oil and see if that helps.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 10-09-2004, 04:18 PM   #4
tErbo b00st
tErbo b00st is an unknown quantity at this point
My head was ticking very loudly too...I had to replace my entire head because the Cams and the U's that cams sit in were worn away more than just bad. Just somethin to think about.
tErbo b00st is offline   Reply With Quote
Old 10-09-2004, 05:28 PM   #5
Var
Var's Avatar
Send a message via AIM to Var
my head was ticking when i started my car..it hadn't been started in about a month. then i took it to a drift event and it went away
Hi
Old 10-09-2004, 10:48 PM   #6
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
air in the lifter dude..im pretty sure i had this same prob...but mine got quite when it was warm but super loud when it started up. sounded like a diesel mercedes rite??
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 10-10-2004, 05:37 AM   #7
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
Sounds like lash adjusters to me start up and is real loud right? And if you rev it it will crack real loud really quickly and then no sound iuntil your rev again right? if that sound like the description of your problem then must be your lash adjusters. rebuild the vavle train if that is the case. eventually they will start chipping and flaking and you will then have chunks of the lashers on your cams and bearing seats and then pow engine give out. IT happend to my 180 oil flush will help with the flakes but you have to replace the lash adjusters IF THAT SOUNDS LIKR THE PROBLEM.
silviasichigo is offline   Reply With Quote
Old 10-10-2004, 12:18 PM   #8
Touring240
Touring240 is on a distinguished road
His problem is that it ticks loud ONCE its warmed up not when cold.
I have the problem that you guys are describing. I had a leaky injector and my oil became diluted in fuel.
After a hard night of driving I heard a ticking coming from the back of the valve cover. When I started it the next day it only ticked for a few seconds when started. It now does this everytime I start it when cold. Suggestions?
Touring240 is offline   Reply With Quote
Old 10-11-2004, 02:22 AM   #9
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
i have a ticking too, im sure its always there but my exhaust is so loud in the car i can barely hear it while driving, ive been told its the lifters, and that is what i think it could be.
how hard would that be to fix?
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 10-11-2004, 03:47 AM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Dont know how loud it is but if u can hear it from inside the car, then its not just the lifters needing to be bled. Could bad valve guides cause it to tick too?
CLICK HERE!!!
Old 10-11-2004, 09:32 AM   #11
sr240mike
Update: The low vacuum was caused by a loose connection to the boost gauge. I used a quart of this oil flush I saw at napa auto parts and changed to a thicker 20w50 as suggested. The oil looked a bit nastier than the last oil change so I guess that the flush loosened up some gunk. I started the car and the noise went away for about 15 minutes and then it came back. I kept driving it for about 2 hours and the noise is slowly going away. Thanks for all the help guys!
