Old 05-06-2017, 07:11 PM   #1
Billcriss
Billcriss is an unknown quantity at this point
Car bursts into flames
Well during my drift event today apparently I had a fuel leak and when my exhaust smacked the ground it created just enough spark to combust. Needless to say my car went up in flames. Luckily we were able to extinguish and save the car. My question is, I obviously don't want this to happen again so is it possible to connect braided fuel lines to the stock sending unit? I know you can connect them to the steel lines but what about the unit? If so could someone send me a product they recommend or have heard about?
Billcriss is offline   Reply With Quote
Old 05-07-2017, 12:36 AM   #2
djdryon
djdryon's Avatar
djdryon has a spectacular aura aboutdjdryon has a spectacular aura aboutdjdryon has a spectacular aura aboutdjdryon has a spectacular aura aboutdjdryon has a spectacular aura aboutdjdryon has a spectacular aura about
Send a message via ICQ to djdryon Send a message via AIM to djdryon Send a message via MSN to djdryon Send a message via Yahoo to djdryon
Braided lines won't stop a leak... they're for keeping pressures consistent. Leaks are still leaks... unless the leak happened from abrasion, in which case braided would still eventually fail. Best thing is to regularly check your lines for signs of wear.
Sent from my SM-G935T using Tapatalk
Contributions: ULTIMATE climate HVAC LED conversion.
djdryon is offline   Reply With Quote
Old 05-07-2017, 07:59 AM   #3
unicoder
unicoder's Avatar
unicoder is an unknown quantity at this point
djdryon is right. Since your car is a track car or 'semi track car' some of the responsibility that comes with that is a lot of inspection and maintenance before/after track sessions.
Just setup a plan for inspecting your stuff efficiently and you'll be good!
unicoder is offline   Reply With Quote
Old 05-07-2017, 08:02 AM   #4
Billcriss
Oh I'll definitely be doing that from now on. I got complacent lol I'll just get new fuel injection line and replace it all to be safe. Appreciate the help
Old 05-07-2017, 02:20 PM   #5
Billcriss
So.... I checked the lines and they look good BUT the sending unit seal is ripped in half.... could this cause a leak?
Old 05-07-2017, 06:50 PM   #6
djdryon
djdryon's Avatar
Yes, it could. Any gas that sloshes out could leak
