Old 10-14-2004, 02:35 AM   #1
fastbacchris
fastbacchris's Avatar
fastbacchris is an unknown quantity at this point
vlsd question
on the top right part theres a little nob. the cap of the nob is bent, so i took it out and theres a little hole/drain(looks like). will this effect it and if so how?
ps.how can this be fixed?
fastbacchris is offline   Reply With Quote
Old 10-14-2004, 08:10 AM   #2
Bone
Bone is an unknown quantity at this point
Send a message via AIM to Bone
Its a breather tube for the rear end. You can hook a hose to it run it up a little and mount it under the body with a check valve on the end of it so it can let the pressure that build in the rear end out. If you block it off you will blow oil out of all kind of places on your rearend. Or you could put the cap back on making sure it is secure where it wont fall off but loose so it can breath around it.
Bone is offline   Reply With Quote
Old 10-14-2004, 12:41 PM   #3
fastbacchris
you know how theres a little rubber seal under the cap should i put it on to? or will that cause the vlsd to not breathe. thanks for the info
