Old 10-16-2004, 10:29 PM   #1
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
KA Help me, '93 KA24DE car won't start right...
KA24DE '93 so here are the symptoms...
start the car, it takes a while to crank up, than dies shorty after
unplug MAS start car, idles fine, only up to 2.5K rev, but if i hit the accelerator, it dies, i can only tap it.
unplug both MAS and TPS car idles rough, and if i hit the accelerator it dies, i can only tap it.
anytime it has the MAS connected, it won't stay running.
My friends and I checked:
TPS resistance OK
MAS connector for voltage and continuity OK
MAS is throwing voltage readings if air is passing though it
anyone know the problem? or someone around torrance wants to come and take a look? i'm clueless now.
240meowth is offline   Reply With Quote
Old 10-17-2004, 01:02 PM   #2
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
try swapping the mafs, sounds like that is the cause of your problems. I'm also told that you can clean the hotwire if its a later one.
andrave is offline   Reply With Quote
Old 10-17-2004, 08:17 PM   #3
240meowth
i have tried to swap mafs, but it didn't work neither, so a possiblity that both of them are bad... anyone have mafs laying around?
Old 10-17-2004, 08:33 PM   #4
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
plug everything back up and try to start it. After thats done check the ECU for codes. If your car is an excepption like mine was it could be the ECU.
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 10-17-2004, 09:21 PM   #5
andrave
andrave's Avatar
clean the connectors and clear the mafs and try swapping it again.
