Old 10-16-2004, 12:44 PM   #1
DORIMON
DORIMON's Avatar
DORIMON is an unknown quantity at this point
My 1st dyno with the SR
I decided to go to the dyno today to tune the SAFC2 on stock boost, almost stock redtop setup. Wasn't expecting much, just wanted to check up on the a/f ratio. I only had time to get in 4 pulls and adjust the SAFC2. The 1st 2 were in 4th gear which hit the speed limiter, the last 2 were in 3rd gear.
S13 Red-Top SR20DET Motor
Stock T-25 Turbo
Heavy Throttle Custom Stainless Downpipe
Heavy Throttle Custom Straightpipe
Greddy Turbo Extension Pipe
HKS Super Power Flow Intake
HKS SSQV BOV (open)
Hotpipe with HKS SSQV welded flange
Turbo XS Standard Manual Boost Controller
Walbro 255LPH Fuel Pump
Blitz LM S13 SR Front Mount Intercooler
Exedy Lightened Flywheel
Timing at 15 BTDC
DORIMON is offline   Reply With Quote
Old 10-16-2004, 01:00 PM   #2
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Is that RWHP or adjusted to be at the crank? Either way, good shiet. What did you end up adjusting on the SAFC? Lean it out a bit on the top end or what?
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 10-16-2004, 03:21 PM   #3
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
i thought it has to be on the rwhp cuz the car is on the dyno itself
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 10-16-2004, 05:10 PM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
hence why he said adjusted.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 10-16-2004, 06:44 PM   #5
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
100$..heads up hood shut race....
lets run...
the curves look good..but you should see a little more power with your setup
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 10-19-2004, 02:43 AM   #6
UcanTry
UcanTry's Avatar
UcanTry is an unknown quantity at this point
Send a message via AIM to UcanTry
hey man what dyno did you go....im from richmond and i was looking for some good places up there to dyno at...
UcanTry is offline   Reply With Quote
Old 10-19-2004, 11:42 AM   #7
ONEBAD240
ONEBAD240 is an unknown quantity at this point
SR
Hey,
I had car dynoed in VA at ARfabrications they did a great tune and in the end put down 420 horse power to the wheels. They have a brand new all wheel drive dyno that is great and i think it cost around 100-150 a hour.
ONEBAD240 is offline   Reply With Quote
Old 10-19-2004, 01:32 PM   #8
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
How much boost were you running? I don't see it listed anywhere.
kazuo is offline   Reply With Quote
Old 10-19-2004, 07:53 PM   #9
FRpilot
FRpilot's Avatar
i was wondering the same. 220ish hp most likely isn't on stock boost. most srs i see stock dynoed are around 180-190 rwhp.
FRpilot is offline   Reply With Quote
Old 10-19-2004, 10:05 PM   #10
DORIMON
DORIMON's Avatar
This was in College Park, MD at SwiftRacingTechnologies (www.swiftracing.com). They charged me $60 for 3 pulls, I got a free pull because they accidentally did a 4th gear run twice instead of once. They usually charge $95 for an hour session, but I believe they might be raising their prices pretty soon. These were all at stock 7psi.
Old 10-19-2004, 10:42 PM   #11
ProjectSlideways
ProjectSlideways is an unknown quantity at this point
we should hang out sometime!
SHIFT______________ owned
ProjectSlideways is offline   Reply With Quote
Old 10-19-2004, 10:48 PM   #12
HaLo
from Canada, eh!
HaLo's Avatar
it's corrected hp to the flywheel?
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 10-19-2004, 11:05 PM   #13
DORIMON
DORIMON's Avatar
I thought it was corrected HP to the wheels. On the dynojet software, the correction factor drop down tab has UNCORRECTED, SAE, DIN, EEC, STD, and JIS, the above graph is in SAE, whatever that means.
Old 10-20-2004, 07:43 PM   #14
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
yeah at stock 7lbs that doesnt sound right.. more like 11lbs or so with those bolt ons. Unless its flywheel HP as others have said.. mine dynoed at 217whp at 11lbs with minor bolt ons and side mount.. plus i had a thicker headgasket but that should matter for too much hp loss.. but now my baby should rip someplace in the mid 300's! FINALLY!
hybrid_eg is offline   Reply With Quote
Old 10-20-2004, 08:53 PM   #15
DORIMON
DORIMON's Avatar
Haha, I'm not gonna argue with you guys. That's stock boost to the wheel. You can believe me if you want. I only posted this thread for those who were interested and needed a reference.
Old 10-20-2004, 09:44 PM   #16
HaLo
from Canada, eh!
HaLo's Avatar
It's pretty impressive... makes you think!! congratulations.
What are the compression results on all cylinders of that engine?
-> HaLo
Old 10-20-2004, 09:53 PM   #17
kazuo
What kind of adjustments, if any, did you make to the SAFC2?
What was the ambient temp?
With 3" exhaust and everything else stock you should be making 180 to the ground on a dynojet @ 7psi.
That's impressive, 40hp just messing with the AFC a little... :O
Old 10-20-2004, 10:55 PM   #18
DORIMON
DORIMON's Avatar
The redtop was from a 93. I was able to pick the one I wanted among the other motorsets at the local importer shop. The one I chose had to be the cleanest, freshest one I have ever seen. The valvetrain was so clean, no sludge buildup at all. The compression was 151, 151, 151, 150. Here' some pics of the day I got it.
Here's all of my safc2 settings with stock SR mafs.
THROTTLE:
LO 20% HI 65%
SENS NO.
IN 6 OUT 6
SENS CAL.
IN 1 OUT 1
CAR SEL.
CYL 4 THR (arrow upright)
DEC. AIR
THR **** %
NE1 10.0%
NE2 10.0%
KNOCKING SET
1. 43 1550 RPM
2. 180 3550 RPM
NE-POINT
HI LO
3000 +16% 0%
3400 +7% "
3800 +5% "
4200 +3% "
4600 +2% "
5000 +2% "
5400 +2% "
5800 +2% "
6200 +2% "
6600 +2% "
7000 +2% "
7400 +2% "
Ambient temp. was:
Run 1: 72.03 F, Humidity 33%
Run 2: 72.72 F, Humidity 33%
Run 3: 72.92 F, Humidity 31%
Run 4: 73.81 F, Humidity 31%
T25, Greddy turbo extension, 3" DP, 3" straightpipe, APEX N1 dual exhaust, hks intake, stock maf, lightened flywheel, Blitz LM fmic, walboro 255 fuel pump, open HKS SSQV bov, TurboXS manual boost controller (turned all the way down, peak boost on autometer boost gauge was 7-psi, .5 bar on blitz turbo timer peak boost hold), timing at 15 BTDC, and safc2.
Old 10-21-2004, 02:11 PM   #19
hybrid_eg
i'm not saying i dont believe you dood, if you did get that much @ 7psi good for you! I'm happy.. the reason why you got so many replies is simply because people dont see that amount of HP on stock boost, simply as that! Mine did not make that even at 11.5psi so there you can see the difference.
Eitherway, good stuff! and great numbers!
Old 10-21-2004, 05:55 PM   #20
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
dang! i wonder if your engine has secrets from japan
wootwoot is offline   Reply With Quote
Old 10-21-2004, 06:15 PM   #21
mrmephistopheles
mrmephistopheles's Avatar
is nobody noticing that he has a FMIC and what appears to me a 3" turboback exhaust?
That, with a little fuel tuning COULD result in those numbers. It may just be that he has a very healthy motor (or maybe his boost gauge wasn't accurate).
Originally Posted by PHLIP
Old 10-21-2004, 06:49 PM   #22
wootwoot
^^^ i noted that but completly stock an sr should put down 170ish whp (assuming 15% drivetrain loss). so that would put him at 50whp over stock...
Old 10-21-2004, 07:01 PM   #23
mrmephistopheles
Completely stock means stock exhaust, stock SMIC, stock intake, etc.
He's significantly NOT stock at this point, only the boost level is stock, and with intercooler especially, his power level will be significantly increased. Fuel tuning will only make it better.
Old 10-21-2004, 07:45 PM   #24
DORIMON
DORIMON's Avatar
Yea, like I said I was very surprised myself when I saw those numbers. I just know that the motor was really healthy when I picked it out from the other redtops.
Old 10-21-2004, 07:54 PM   #25
wootwoot
i see what your saying mephy im just really impressed. i know what stock is, but he doesnt have anything beside simple bolt ons really. its just damn good, maybe i'll dyno my similar set up soon and see how that goes.
Old 10-21-2004, 08:35 PM   #26
hybrid_eg
like i said.. number are amazing.. almost too good to be true.. and as i have said i'm not doubting your motor or the mods you have, but i would also suggest going to another dyno if you ever get a chance as i have heard numerous rumers that dynos can be changed with ease to read higher numbers then what they really are. Either way all that is important that motor has some great compression numbers and seems clean as it can possibly get. Good luck with the car and your project!
Old 10-21-2004, 09:31 PM   #27
kazuo
So, yeh. You're wrong. Stock everything SR puts down 160 per SCC's dyno. on a dynojet.
3" exhaust and stock everything SR puts down 180 per SCC's dyno and my friend's dyno. on a dynojet. Link to my friends chart = 180hp dyno on a dynojet
With a FMIC, AFC + light tuning and 3" exhaust, as mr. myzpixtixixipoxufcoidsgyfijds pointed out, it is not far-fetched for him to get that amount of power from moderately low boost, although it is possible his gauge is reading wrong.
DORIMON, where is your gauge getting its source from?
Old 10-21-2004, 10:00 PM   #28
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
nice numbers benji, i have the exact same setup as yours except instead of an FMIC i have an ARC SMIC. alot bigger than the stock side mount but not exactly riding with the big boys yet. - oh and I have an S-AFC. Its not installed tho...
do u run those NE points on the stock boost setup only? do u have a different settings for when you run higher boost?
i hope to get simlar results as you.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 10-21-2004, 10:13 PM   #29
DORIMON
DORIMON's Avatar
The Autometer mechanical boost gauge (which is known for inaccuracy, I know) is teed off from the vaccuum line that goes from the fpr to the throttle body. The Blitz Type-X Dual Turbo Timer has a boost gauge as well in bar, and the peak hold function never goes past .5 bar. Its teed off in the same location. My autometer's accuracy is pretty on point as it reading the same as the turbo timer, awhile back I also swapped the autometer gauge with another autometer gauge that didn't have a vacuum just to test if mine was off, this was before I got the digital turbo timer. Anyway, with the turboXS manual boost controller turned all the way down, the peak boost hold is the same as when I had no boost controller installed at all, so the actuator isn't faulty, just to rule that factor out.
Yea, I only had enough time for 4 pulls which I was able to tune for 7psi, which was enough for me for last Thursday and Sunday's events. I'm not planning on raising the boost anytime soon. I'm pretty satisfied with how the car is running right now. I really wish I could've done more pulls so we could see how the a/f changes as the boost increases. I'll go back sometime next month when they're not so backed up with appointments.
Old 10-22-2004, 07:06 AM   #30
Silverbullet
which place and how much for 4 pulls?
HouseBuyers365.com
