Old 12-31-2017, 08:59 PM   #1
hyde097
hyde097 is making his/her stupidity well-knownhyde097 is making his/her stupidity well-knownhyde097 is making his/her stupidity well-known
Parts needed to complete 5 speed swap
5 speed swapping my S14. Got a trans, shifter, and master/slave/hard line assembly. What do I need to complete the swap? Never done anything like this and I barely know how to drive a manual so know very little about what’s needed to complete the conversion. All I know is that I don’t have a clutch fork or clutch assembly/pedal. Any info is helpful.
Thanks.
File Type: jpeg 0380E4AD-5330-458A-85F6-208C749EA083.jpeg (349.7 KB, 24 views)
hyde097 is offline   Reply With Quote
Old 01-09-2018, 03:29 PM   #2
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
You'll need a manual trans cross member. Might need a 5 spd driveshaft too. There should be a swap guide somewhere on the internet for this.
240sxScores is offline   Reply With Quote
Old 01-09-2018, 03:48 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
wow, is today national "I can't use google on my own" day?
http://lmgtfy.com/?q=240sx+5+speed+swap
Old 01-09-2018, 03:54 PM   #4
JustinChillenBallin
JustinChillenBallin's Avatar
JustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymoreJustinChillenBallin is not welcome here anymore
Send a message via AIM to JustinChillenBallin
he's from Kentucky, cut him some slack!
JustinChillenBallin is offline   Reply With Quote
Old 01-09-2018, 09:14 PM   #5
drifter5
drifter5 is an unknown quantity at this point
Just did mine last year on a '95 S14.
Looks like you're still missing...
-Driveshaft
-Pressure Plate Bolts
-Clutch + Pressure Plate
-Flywheel
-Flywheel bolts
-Dust Cover
-Bell housing bolts
-5 Speed brake pedal (or you can cut your existing one)
Also make sure you get an S14 transmission otherwise if you use an S13, you will have to drill a hole for the CAS and figure out the wiring required for the speed sensor.
I also swapped ECU on mine to a 95 5-speed to get rid of the CEL.
drifter5 is offline   Reply With Quote
