Old 01-19-2016, 12:12 AM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
SR20 Dual Guide Conversion
There isn't much information on this subject... Curious why?
Either way what exactly are the steps to this?
I shaved all my rocker arms to fit a dual guide on both sides.
One thing i know is that guides are all the same size, unlike shims.
So, does the rocker arm its self have to be shimmed to size, or do i just slap the guides in and rock and roll?
Or is there a way to stick a feeler gauge between the cam and rocker arm to test clearances?
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 01-19-2016, 10:48 AM   #2
jr_ss
All the guide shims are the same thickness. There's no adjustment for them.
Old 01-19-2016, 02:38 PM   #3
Options13
Options13's Avatar
Trader Rating: (43)
so then it would be required to shave the rocker arm down to spec?
Drift team page
Old 01-19-2016, 02:44 PM   #4
Driftzenki
Driftzenki is an unknown quantity at this point
when I did my conversion I made sure they were max .003 of an inch apart from each other with a dial indicator and custom tool that goes inside lifter hole, haven't given me any problems since, may have to switch guides around due to normal wear
Driftzenki is offline   Reply With Quote
Old 01-19-2016, 07:02 PM   #5
jr_ss
You don't shave anything. The rockers are modified for the dual guide and then installed in the position they were pulled from. There no shimming or trimming, when this mod is performed. Install the cams and go. Now what might affect it is valve stem height. In which case, much more work would need to be performed.
Old 01-19-2016, 09:00 PM   #6
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
You need to measure/adjust the rocker arm clearance same as a normal single guide SR.
The trouble is the guided shims only come in one thickness so you need to adjust the clearance another way (normally valve stem). Brewed Motors builds dual guide SR20 heads with the rockers/valves all within spec.
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 01-19-2016, 11:44 PM   #7
Options13
Options13's Avatar
Trader Rating: (43)
i called mazworx, and they said to remove material off the rocker arm itself untill it is within spec.
Drift team page
Old 01-20-2016, 09:11 AM   #8
jr_ss
What is the "spec" though? As far as I can recall, there is no rocker to cam clearance spec in the FSM. It's strictly directed towards getting the rocker level to the cam lobe so that both valves actuate the same time and amount of lift. I don't have an FSM available to me ATM to clairify so, some one please enlighten me.
Old 01-20-2016, 09:29 AM   #9
smartoss
smartoss is an unknown quantity at this point
You can get different thickness guides from Tomei. http://www.frsport.com/index.php?tar...&q=Tomei+guide
smartoss is offline   Reply With Quote
Old 01-20-2016, 10:15 AM   #10
Options13
Options13's Avatar
Trader Rating: (43)
Oh I might be mixing up my words, I mean, you may have to remove material off one of the guides to ensure that the rocker arm is level with the cam. I did more research last night, I feel like wet sanding the guide *if needed* to get the rocker arm level would be the best way comapred to grinding the rocker arm.
I'm going to try and mock up a tool today, by welding a stand to an extra hydralic lifter, so I can measure how thick I need the guide to be.
Drift team page
Old 01-21-2016, 01:13 AM   #11
Options13
Options13's Avatar
Trader Rating: (43)
So i was finally able to rig up a dial to measure all the size shims i need.
Unfortunately Tomei doesn't make a big enough guide for some of my valves..
Here's the size shims i need for each rocker arm.
would the best route, just to go to the dealership and find the closest shim i can to each measurement i can?
Drift team page
Old 01-21-2016, 06:24 AM   #12
R3cK
R3cK is an unknown quantity at this point
why would you do a dual guide?
just use one guide and one shim in the size needed.
measuring the size is pretty salty tho.
i let the work do by a person that made himself the measuring tool with a cnc machine. its basically a solid hydraulic lifter copy with the ability to mount this pressure measure clock thing. the problem is it never fits 100% tight so you have to constantly push it a bit to the shim points.
R3cK is offline   Reply With Quote
Old 01-21-2016, 10:39 AM   #13
jr_ss
KA
This modification basically prevents the rockers from kicking off in the event of bouncing off the rev limiter. It's a common upgrade to higher revving SRs.
Old 01-21-2016, 10:42 AM   #14
pTen
pTen is an unknown quantity at this point
*helps prevent
pTen is offline   Reply With Quote
Old 01-21-2016, 10:42 AM   #15
jr_ss
Originally Posted by pTen View Post
*helps prevent
Yes, thank you.
Old 01-22-2016, 03:18 AM   #16
TheRealSy90
TheRealSy90's Avatar
Honestly, I've done dual guides in a bunch of sr20's by just throwing them in and going for it. The hydraulic lifter can usually handle the slight difference in shim height if there is one, as long as they are all fairly close.
Now, on my personal Sr i have the guide shims machined to match the thickness of each flat shim that it replaces, so that it maintains the exact same clearance.
It's up to you which way you do it. But every one I've done it to with just throwing them in and going has never had a problem, and never threw a rocker arm again. The difference in thickness is so minute.
I made a "How-To" video a couple years ago to explain this mod and how to do it, as most people don't know about or understand it. https://youtu.be/StxF9aLMoSg
Such a good signature.
Old 01-22-2016, 05:24 AM   #17
R3cK
interesting.
here in germany we just put RAS in and nothing bad ever happened.
never heard of dual conv. here.
Old 01-22-2016, 06:51 AM   #18
jr_ss
interesting.
Understood. The problem with RAS is they prevent the rocker from flying free and clear when they are tossed. This ultimately ends up with either broken rocker arms, bent valves, damaged pistons or all of the above.
Old 01-22-2016, 09:16 AM   #19
Trion
Trion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enough
I have had dual guide shims for a couple of years now. The only right way to do it is to grind the guide shims to correct thickness. I never allow more than 0,02mm difference in clearance between cam and rocker arm.
When in need of thickness greater than 3mm, I use a shim (a thin washer) under the valve lifter as recommended by Mazworx.
I run it with tomei solid lifters and RAS. Never had any issues with throwing shims and rockers after installation.
Sent fra min C6603 via Tapatalk
Trion is offline   Reply With Quote
Old 01-22-2016, 11:27 AM   #20
Options13
Options13's Avatar
Trader Rating: (43)
i ended up just ordering the proper sized shims for my head, but what kind of washers did you use trion? A standard washer with a hole in the middle of it ?
Once my shims arrive, i will be putting my head back together without the RAS.
I'm still debating on if i want to put stock lifters back in or run my after market ones..
Drift team page
Old 01-22-2016, 10:37 PM   #21
Options13
Options13's Avatar
Trader Rating: (43)
so my damn shims are back ordered for another week so i decided to just do the dual guide conversion.
What i did was shave the bottom of the guides till they were "level" with the other guides.
Now all my guides are either perfectly level with it's partner or within .001mm difference.
I'll put the head back together this weekend, and hopefully not throw any more guides!!!
Drift team page
Old 02-05-2016, 05:06 AM   #22
Tyler_240
Tyler_240 is an unknown quantity at this point
Did you get everything back together? I noticed a few posts above suggested we can just throw the new guides in if we're using OEM valvetrain because they are all one size.
So did you "shave" your guides because you were running after market lifters?
Just wondering. I recently tossed a shim/rocker and I had RAS, and the rocker ended up riding on the spring retainer and i found the shim laying nearby...
I'm getting my rockers machined for the dual guides but want to confirm whether I need to measure the new guides or not.
I'm using OEM valves/springs/retainers/lifters/cams.
Tyler_240 is offline   Reply With Quote
Old 02-05-2016, 07:12 AM   #23
Options13
Options13's Avatar
Trader Rating: (43)
I did the mod, and I still tossed a guide, so I see this as a pointless mod... If you are throwing shims, something isn't right in your head..
I upgraded to jwt s4 cams, and I went back to stock springs and retainers. I had BC springs and if your springs are too stiff for hydraulic lifters it could be counter productive. Also all guides are the same size so it's hard to get the rocker "level" with the cams.. I went back to the standard guide/shim.
If there is enough movement in the rocker arm, you will still break the walls in the guides.. IMO this conversion isn't worth it.
Drift team page
Old 02-05-2016, 07:29 AM   #24
jr_ss
Try not beating the shit out of the rev limiter. That usually helps.
Also, no one said it was a fix-all for launching rocker arms. It helps prevent it. Perhaps you have more pieces out of spec than you initially presumed?
A fix-all would be swapping a VE head in.
Old 02-05-2016, 07:35 AM   #25
Options13
Options13's Avatar
Trader Rating: (43)
Funny thing is, I didn't hit rev limiter when I popped two rockers out.
Drift team page
Old 02-07-2016, 04:46 PM   #26
jr_ss
Then you have other issues you need to look into. There is no reason you should be launching rockers with upgraded springs and not bouncing off the limiter.
Old 02-07-2016, 06:41 PM   #27
Options13
Options13's Avatar
Trader Rating: (43)
My theory is that the springs that were in the head are too stiff for the hydraulic lifters, thus making it counter productive.
I'm going VVL now.. lol
Drift team page
Old 02-10-2016, 05:14 PM   #28
TomBec
TomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond reputeTomBec has a reputation beyond repute
im in the middle of the dual guide swap myself. i did some looking around and found a aussie company that manufactures SR20 shims to pretty much any size between 1 and 5mm. going to machine the rockers myself and order guide shims as close to the size of the pivot shims i can get. once i fish the rest out of my oil pan, of course.
might be worth checking out. http://www.precisionshims.com.au/
TomBec is offline   Reply With Quote
Old 02-10-2016, 08:12 PM   #29
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
^ or you could just order guide shims from the dealer.
I would go to Nissan race shop dealer, and order OEM
Dboyizmlg is offline   Reply With Quote
Old 02-17-2016, 09:07 AM   #30
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
The thing that scares me/makes me question shimming in most cases are that most people have cheap measuring tools, in which i'd highly doubt accuracy. Atop of that, how many 'shim guys' are actually doing it "the right way"? Very few.
Lets also consider this: Your zillion mile SR has developed a wear pattern across the rocker top. You shim it properly, but now put new cams in. There's got to be a gradiant wear, and for sure a 'ramp profile' wear difference ya know? Also, how are you to account for rocker tip wear? Or across the 'pad' still being perfect?
Or lets say you got an engine that someone put FuckBoi Seat stomping springs and retainers in, lets say with a unknown shit cam that you now decide to change back to a 'stock' cam or a differnt brand? I wonder how many people even look at or consider looking at the rocker pad surface again?
So even with shimming...if you're not reusing the exact same 'combo' how can we really say it's evenly running against the cam surface? Sure the HLA takes up slack on the one end, and the spring deflection the other, but what's to say that the rocker pad itself is even, well 'even'?
Just some food for thought for those stressing out over it all. Do i have the tools? Yes. Have I shimmed them? Yes. But in other end, I've also not and never had an issue. IMO the biggest issue people have aren't freakin torquing it properly and tearing out threads or snapping cams.
So some things I've learned over the years
- I've had engines with yahtzee shim syndrome, slapped it all back together without shimming and they've gone thousands of miles without any lick of issue, or worry
- Dual guide conversion has been around forever. Know how many FWD guys just throw two in and role and never know the difference or ever have an issue? Like zero. 8000 rpm with a 'quality' cam, stock valvetrain, no worries
- I've even had track engines toss rockers and shims mid day. Put new shit in, and ship it. Problems? Never. End up spinning a rod bearing from the FWD pan sucking ass before anything haha.
In a perfect world with a good tool (like the CustomSteel one, or a good home made unit) on a bench with a good tool? Sure. But if you don't do it perfectly will it explode into a valvetrain fireball? Of course not. I'm sure my answer isn't 'perfect' but it's real world. It's not like we're building mechanical valvetrains here, we're still ultimately using a crappy hydraulic lifter....
