Old 11-02-2004, 01:10 AM   #1
prelude180
prelude180 is an unknown quantity at this point
Power FC abilites?
Althogh this is kind of a blanket statement, but what can the power fc not do. I heard that it can detect all sorts of engine problems, like sensor failure. What can it not detect?
prelude180 is offline   Reply With Quote
Old 11-02-2004, 11:58 AM   #2
Flybert
Are you lazy or just a dumbass?
http://www.apexi-usa.com
Old 11-02-2004, 03:52 PM   #3
TheSmuggler00
TheSmuggler00 is an unknown quantity at this point
shit i heard the main reason alot of ppl got it was to convert to MAP sensor so theat the maf dosent cause stumbling when they vent to atmo =)
TheSmuggler00 is offline   Reply With Quote
Old 11-02-2004, 05:41 PM   #4
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
Main reason is for easier and better tuning.
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 11-02-2004, 06:11 PM   #5
prelude180
Don't worry, I checked the site, but it says on their that it can check to see if a sensor is in use or malfuctioning. I was asking if I can do this for all sensor and engine parts? Also if you remove the MAS for a MAP sensor, where do you plug it in?
Old 11-02-2004, 08:29 PM   #6
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
It wont work like the F&F stand alone. I wish I had one of those...
You will need the D-jetro model, and it will come with the sensors. you will want to drill a hole in your intake manifold and instal the sensors, near the runners if you can.
TheSnail is offline   Reply With Quote
Old 11-03-2004, 12:01 AM   #7
prelude180
thanks for the info. Does a MAP equpied jetro have more potential then say a z32 MAS with a standard fc? Also what about a drag-pro power fc? how does this compare to the jetro and the standard?
Old 11-03-2004, 12:21 AM   #8
TheSnail
TheSnail's Avatar
Yes, it has more potential then any maf. It is more precise, and has unlimited boundaries. As for a comparison between the two standalones, I believe the drag one is maf, and has a launch set, where you would be able to gun it in neutral and the rpm's will only go up to what you set it to. There is also a setting where when you shift, it only goes to a set rpm while never taking your foot off the gas. There is also one that is in between the drag and D-jetro, It starts with an L and it also uses map, I cant think of the name, I will have to ask my friend tomorrow. Unless you’re going for drag, I would go with the D-jetro, or the plain pfc.
Old 11-03-2004, 11:16 AM   #9
TheSmuggler00
I'd go with D-jetro b/c that map will make you happier in the long run
Old 11-03-2004, 02:34 PM   #10
prelude180
I had read somewhere that after every mod you add to the engine, if your pfc is jetro, you will need a retune? Is this true?
