Old 11-03-2004, 11:14 PM   #1
SaGang227
SaGang227 is an unknown quantity at this point
Quality of old flywheel?
I did some search and it seems like flywheel in all 240SX are same no matter what year they are.
So I am thinking about buying an S13 flywheel for my S14 because they are cheaper to buy from junkyards.
But I wanna know if it is ok to use older flywheel as long as I resurface it.
Would their be any performace/safety issue with old flywheels?
SaGang227 is offline   Reply With Quote
Old 11-05-2004, 08:47 AM   #2
SaGang227
Anyone know?
Old 11-05-2004, 05:40 PM   #3
orion::S14
orion::S14's Avatar
There is no problem as long as it's got no more than a little surface rust.
Resurface it and install it, done deal.
.75" thick pieces of hardened steel are hard to mess up.
- Brian
www.KA24DEvelopment.com
Old 11-05-2004, 06:29 PM   #4
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
actually yeah there are major problems that can happen with a old flywheel or one thats not the same diameter or thickness. If you get an old with that has defects like cracks or its got hotspots or have been resurfaced to much it may not work at well as you think it should. For instance you might not get into gear if its to thick. But naturally if its old you bound to come across some problems sometime down the road.
You better off buying a new flywheel. Its only like what 50 something plus your old flywheel.
kick rocks.
Buffalo Daughter is offline   Reply With Quote
Old 11-06-2004, 04:49 PM   #5
doainwpg
doainwpg is an unknown quantity at this point
by the way the flywheels aren't all the same, SOHC & DOHC flywheels will both bolt upto any ka crank however they use different clutches
Life's the race everyone's dying to win
Free Ipods Here
doainwpg is offline   Reply With Quote
Old 11-07-2004, 12:58 AM   #6
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
Yea the last time I was told by the machine shop at NOPI that my flywheel is down to the last resurface I sure toasted that pancake good. so yea... You might find flywheel that don't have much meat left...
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 11-07-2004, 12:53 PM   #7
SaGang227
Thanks for the replies guys.
I would still be able to use S13 DOHC flywheels for S14 right?
No go for new flywheels.
Dealership wants $300 plus for it and I am looking to spend under $50.
I'll keep looking around.
Old 11-07-2004, 05:13 PM   #8
orion::S14
orion::S14's Avatar
Search www.car-part.com for an S14 flywheel in VA...
There are 2 for $50 when I just looked.
- Brian
