Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > R Chassis
R Chassis Technical discussion related to the R Chassis such as the R31, R32, R33, R34, and R35.
Old 07-27-2019, 01:40 PM   #1
Rb25detJay
Rb25detJay is an unknown quantity at this point
RB Rb25det Running ROUGH
Hey guys I have an rb25det swapped 240sx which i received recently.
I changed the following things recently
spark plugs from brp6es to brp7es
Coil packs from Yellow jackets to splitfires
I noticed it was backfiring on idle and when I revved it, it seemed to be revving rough or have some sort of lag.
I gapped the brp7es to .28 and the backfiring at idle stopped.
However, the rough idling and the rough shaking still stays, any ideas on what it could be ? Thanks
I'm relatively new to the S chasis and the RB, any and all help would be appreciated.
Rb25detJay is offline   Reply With Quote
Old 09-20-2019, 04:44 PM   #2
S14rebuild
1st post=1 reply......did u check timing?
Old 09-22-2019, 02:33 PM   #3
BenRice
BenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura about
If it already had Yellow Jacket's in it then someone's encountered this issue before and tried to fix it.
When you swapped the plugs, what did the old ones look like? Black? White? Or all different?
Check the grounds for the coilpack harness - not just the connection, but the wire in the terminal might be cracked. Better yet, run fresh grounds from the coilpacks, even temporarily to check if that's the issue.
After that, throw a fresh fuel filter at it and double check the voltage at the fuel pump
BenRice is offline   Reply With Quote
rb25det
