Old 10-27-2018, 11:21 AM   #1
MeowMR2
MeowMR2 is making a name for him/her selfMeowMR2 is making a name for him/her self
1jz VVTI No power till boost
Hi fellas, I have been searching for answers only to end up with Hey I fixed it, End of thread.
The Setup
X8
1jz vvti stock
J-pipe delete
Future Fab DP
r154
OEM JZX100 MT ECU
MK4 Supra TT fuel pump
Injectors are cleaned and rebuilts by witchhunters
New OEM toyota TPS
The Problem:
The car from Start feels like n/a No power until boost kicks in around 3.5-4k, and it rips!!! but as soon as i shift, the car has no power. OBD- Does not work, so we cant get codes. I unplugged and removed the sensors for TCS on the throttle body. Wiring is all done by me, if you have questions, I will try explain as best as i can.
Thanks for the help.
MeowMR2 is offline   Reply With Quote
Old 05-05-2019, 06:06 AM   #2
Syrussilvia
Syrussilvia is making his/her stupidity well-knownSyrussilvia is making his/her stupidity well-knownSyrussilvia is making his/her stupidity well-known
Try another ecu JZX100 ecu's tend to blow capacitors. If you are in anaheim Im in Westminster and you can try my ecu to see if it helps PM me.
Syrussilvia is offline   Reply With Quote
