2JZ > S14 swap parts (Harness, Driveshaft, Xmember, etc)
Parting out a few things from my S14 2JZ swapped chassis.
1. Wiring Specialties P&P 2JZ vvti > S14 (AEM INFINITY 6) $1050 shipped Harness is for the following: - s14 2jz vvti AEM Infinity 6 p&p - R154 trans - ID injector style plugs - maf delete - dbw delete (using driftmotion dbw delete kit) - o2 delete - vsv delete - removed map sensor and replaced with AEM MAP sensor plug. + fuel pressure sensor plug added directly to infinity + oil pressure sensor plug added directly to infinity + 4.2 lsu plug sensor added directly to infinity + aem boost solenoid plug added directly to infinity ![]() 2. SR20 Koyo & Flow radiator. $220 shipped - 0 leaks, had absolutely no overheating problems running this with Flexalite 420 fans. ![]() ![]() 3. Xcessive S Chassis to Toyota Manual Transmission Cross Member $60 shipped - Works as designed. ![]() ![]() 4. CXRacing Aluminum Radiator Water Hard Pipe Kit $60 shipped - 1/8 npt for coolant temp sensor ![]() 5. R154/240sx 1pc Steel Driveshaft $240 shipped - works as designed ![]() 6. S14 Sikky Swaybar $240 shipped ![]()
IG: @ozc2jz |
Cool Dude! legit seller, GLWS!
Check out my Build Thread!http://zilvia.net/f/showthread.php?t=650464 |
