Old 04-25-2020, 08:49 PM   #1
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
CA S13 Kouki Aero OEM Type X
https://ibb.co/44RhSZ1
$10k FIRM
Engine/Performance:
S13 SR20det Red Top (316 WHP on CA91)
Only ran Mobil 1Full Synthetic 10w30
Rywire harness
Modified valve cover with custom catch can and AN lines
LS1 coilpacks
AEM V1 PCM
Gates Micro V Belts
Mazworx timing Chain Tensioner
S14 SR Water pump and modified neck for temp sensor
Walbro 255lph Fuel Pump
Chase Bays returnless fuel setup and AN lines
AEM FPR
Radium top feed rail ID 1050cc injectors
TIAL vband Wastegate on OEM manifold (atmospheric dump)
AEM MAP sensor
AEM Boost control solenoid
Greddy 2 Row Radiator
AEM Digital Wideband gauge
AEM water temp gauge
Nismo Thermostat
Custom SS Power Steering line. Similar to Chase Bays line.
7 layer S15 Exh. Manifold gasket
Garret GT2871 .64
HKS 264/264 Step 1 Cams
Earls SS Oil and Coolant lines
TIAL BOV
Greddy FMIC
Custom 3? Downpipe with flex section
Catco 3" high flow cat(gutted)
ISR 3" blast pipes(loud)
Circuit Sport Poly Exhaust Bushings
DIF SS Fire Sleeved Clutch line
6 Puck Clutch
PBM Magnetic drain plug
ATP short shifter
Suspension:
Powered By Max Coilovers
Powered By Max style drop knuckles(exact copy)
Brand New FLCA's and extended 25mm + gusseted
Brand New Maxima Moog Inner Tie Rods
Just got an alignment 4/25/2020
SPL Version 1 Toe Rod's
SPL Version 1 Traction Rod's
SPL outer Tie Rod ends(bump steer correction)
Kazama RUCA's
Driven08 Eccentric Lockout Kit
Nismo 2 way LSD(real quiet after the Ford friction modifier)
Villains modified axle stubs for Z33 axles
Circuit Sport Tension Rods
Johnny Fraz Tension Rod Brace(Like Nismo Brace)
Energy Suspension Front Sway bar bushings/endlinks
Energy Suspension rack & pinion bushings
Z32 Rear 5 Lug Hubs
Attain 5 Lug Front hubs with extended ARP studs and legit open end nuts
Brakes:
Z32 30mm Front Calipers w/ss lines & slotted rotors
Z32 Rear Brakes with working Ebrake w/ ss lines & slotted rotors
Z32 Rear Ebrake Assembly w/ powdercoated black backing plates
Project Mu Ebrake shoes
*Brand New Z32 1? BMC
*Brand New Ebrake Cables
Driven08 Z32 2+2 Ebrake cable bracket
Wheels/Tires:
Advan RGII
Front: 18x9.0 +22 w/ 7mm Powered By Max Spacer(effective +15 offset)
Rear: 18x10.0 +15
Exterior:
Mercedes Black Single Stage Paint
Kouki OEM Bumper
Kouki OEM Turn Signals
Kouki OEM Position Lights
Kouki OEM Extensions
Kouki OEM Extension Brackets
Kouki OEM Sideskirts
Kouki OEM Valences
Kouki FPR Center Valence
Kouki FPR OEM Style Spoiler
Driven08 Kouki FPR OEM Style Lip (super flexible and strong)
Kouki OEM Tail lights
Raybrig H4 Housing Headlights
6k HID?s
M3 Clear Sidemarkers w/ leds?s
Interior:
Black Dash
Safety 21 6 Point Cage
Nardi Deep Corn 350mm
NRG Short Hub
NRG QR
Bride Zeta III w/ Gradation
Bride FG Sidemount rails
S14 Passenger seat
Dyed black rear seats
Black wrapped glove box
Full Interior
S14 Manuel Seat Belts
DOHC Cluster w/ SR RPM
Newish Turn Signal and Wiper Stalk
Leather Shift boot
More pics coming soon
As long as you're not a ham-fisted retard there shouldn't be a problem.
Psychomoongoose is offline
Old 04-28-2020, 01:56 PM   #2
Psychomoongoose
Car sold back to Driven08 for $10.5k
Please lock
kouki 180sx, s13, type-x
