Old 11-20-2008, 12:09 PM   #1
Japan88
Japan88's Avatar
Japan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to allJapan88 is a name known to all
Subframe Spacers
I put on subframe spacers to stop the slop on my car. Once they were on i drove my s13 around for a whilethinking they had to set in. After a while i still heard the SLOP sound on my car. So i dont know what else it could be. Maybe tranny mount?? any helpers thanks
Japan88 is offline   Reply With Quote
Old 11-20-2008, 12:19 PM   #2
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
what is a slop sound?
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 11-20-2008, 12:25 PM   #3
Japan88
Japan88's Avatar
Im not sure how to explain the slop sound. umm when i break, the back of the car would lift up and make a slop sound or a slap sound when 2 hands clap. but with the subframe spacers, it should have taken that off, i can feel that ther car doesnt lift up anymore, but the sound is sill there.
Old 11-20-2008, 12:26 PM   #4
mobilesuit818
mobilesuit818's Avatar
mobilesuit818 is an unknown quantity at this point
It could be a combination of all your mounts.
Tranny, Engine, FLCA, Diff, subframe, etc.
Quality is not expensive, its priceless.
mobilesuit818 is offline   Reply With Quote
Old 11-20-2008, 12:29 PM   #5
burnsauto
burnsauto's Avatar
its prob something else besides the subframe if you bolted that sucker up good and tight. Have you checked out all the other bushings in the rear end (diff mounts, etc?)
Old 11-20-2008, 12:33 PM   #6
Rnz520
Rnz520's Avatar
Rnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud of
Send a message via AIM to Rnz520
check your carrier bearing
*93 240sx:KA-T, FLTA-2s, MR TR, Greddy F&R bars, Greddy gauges, Cusco brace, etc
Rnz520 is offline   Reply With Quote
Old 11-20-2008, 12:47 PM   #7
Japan88
Japan88's Avatar
I havent check any other mounts yet, i was hoping you guys might of had the same problem and pin pointed out the problem right away. But i am gonna have to check all those things out and i never thought of checking the carrier bearing. So ill check that out today and come back with my results.
Thanks peeps
Old 11-20-2008, 01:42 PM   #8
Japan88
Japan88's Avatar
I just got to work and while i was driving the car it still made the slop noise as i shift gears and as i step on the gas. Not to much noise when i step on the gas. Just giving you guys more info. But i will be checking everything (mounts) later on today.
Old 11-20-2008, 02:44 PM   #9
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Look at the other bushing thread on this page.
Sounds like the exact same thing to me.
lol... did you recently immigrated to the US? You sound like I did after a year learning the language.
Old 11-20-2008, 02:49 PM   #10
Japan88
Japan88's Avatar
The carrier bearing from the drive shaft? How would i know if its bad?
Old 11-20-2008, 06:39 PM   #11
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Subframe spacers don't help if the subframe bushings are completely annihilated. Maybe you should check to see if you still have play in the subframe bushings...
-Kyle
Old 11-20-2008, 11:21 PM   #12
Japan88
Japan88's Avatar
Ill check that out tommorow to see how they are.
thanks.
Old 11-20-2008, 11:26 PM   #13
victorw210
victorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choices
i ripppedd my tranny mount in half and it was all like wowowowowowofapapapap
victorw210 is offline   Reply With Quote
Old 11-20-2008, 11:47 PM   #14
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
is probally your diff. my freind had the same noise because the previous owner didn't tighen down the rear two diff bolts. try that of the 2 bolts in the middle of the drive shaft that hold it up.
Hope this helps good luck...
wow-thats-a-cool-car is offline   Reply With Quote
Old 11-21-2008, 08:33 AM   #15
PBucch
PBucch's Avatar
PBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfection
Still working on it I see.
OP, Check the toruqe on the subframe bolts....
section ef&ec changed my life
PBucch is offline   Reply With Quote
Old 11-21-2008, 09:21 AM   #16
Grimsta
Grimsta's Avatar
Grimsta is an unknown quantity at this point
Your carrier bearing you check by shaking the DS. If there's hella play in your bearing, like if the DS moves around alot in the housing, you're done.
But other than that, all your bushings and rear suspension and chassis bolts are definately where I would start looking. Just put a wrench on your bolts and make sure everything's tight as well
Grimsta is offline   Reply With Quote
Old 11-21-2008, 09:24 AM   #17
ericcastro
ericcastro's Avatar
you sure you dont have a baseball in the spare tire wheel well? It could be rolling around and making noise when you stop?
lol
really though, are you sure its mechanical or is it something moving around in the interior?
Old 11-21-2008, 07:23 PM   #18
Japan88
Japan88's Avatar
lol
Hahah nope there no ball back there. and i found out the problem but i dont know what part it is? dif mount?
i need bushings in that area were i circled in red with a "?" mark. were can i get those bushing?
Old 11-22-2008, 11:46 AM   #19
Japan88
Japan88's Avatar
Old 11-22-2008, 12:28 PM   #20
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
The rear differential is what I was thinking. I believe that that paticular differential does not have bushings. There is a tiny hole where the bolt slides into and bolts into the frame. The S14 and Skyline have the bushings.
Have you tried to torque down the bolts?
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 11-22-2008, 12:35 PM   #21
soon2bs13
soon2bs13's Avatar
here is a picture of what i am talking about. no bushings.
Old 11-22-2008, 11:49 PM   #22
Japan88
Japan88's Avatar
Have you tried to torque down the bolts?[/quote]
I havent tried thats yet. i was hoping i could find bushing for it? But im still goona try tightning it more down but if thats the max then i would need bushings.
ANy idea were i could get some>?
Old 11-23-2008, 12:54 AM   #23
soon2bs13
soon2bs13's Avatar
That is the thing, if the picture I posted is the same part as yours. There are no bushings required. If you needed the bolts/spacer or something, I have the stock ones that did not seem to have any issues.
You could go to a local junk yard and have them get the parts.
Old 11-23-2008, 01:02 AM   #24
Cake Is Dope
Trader Rating: (36)
Cake Is Dope will become famous soon enoughCake Is Dope will become famous soon enoughCake Is Dope will become famous soon enoughCake Is Dope will become famous soon enoughCake Is Dope will become famous soon enough
Feedback Score: 36 reviews
SPL PARTS solid diff bushings
Cake Is Dope is offline   Reply With Quote
Old 11-23-2008, 01:07 AM   #25
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
ay japan88 i think i saw you like 2 days ago
ate late
airhead is offline   Reply With Quote
Old 11-23-2008, 11:18 AM   #26
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
His Diff HAS bushings, clearly.
Did you not see the picture?
Bigsyke is offline   Reply With Quote
Old 11-23-2008, 11:45 AM   #27
Japan88
Japan88's Avatar
Alright cool. i fixed the problem just by going to the local Ace Hardwear store and buying bushings. haha.
thanks guys.
Old 11-23-2008, 03:40 PM   #28
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
For the past few months, I've been getting a lot of noise coming from the rear. Everytime I would accelerate and then let off the gas, I hear a loud clunk. Also going over major bumps, I could also hear some noise.
I finallly found a good deal on some used SPL subframe collars and installed them today. It not only fixed my problem but it improved the ride and comfort. It is such a night and day difference. What baffles me is that when I installed the spacers and checkout my rubber bushings in the subframe, they looked perfect. They wern't cracked or even dry.
But in the end, I am so happy it fixed my problem. Now the car is much more drivable.
garagelu is offline   Reply With Quote
