Old 10-23-2020, 07:48 PM   #1
wavess13
wavess13 is an unknown quantity at this point
Noise at differential/driveshaft
Hi guys,
I am getting a clunking noise during decel (foot off gas).
Jacked the car up, this is what is happening:
https://vimeo.com/471606782
I am getting noise and play at the driveshaft / differential.
I have a new 1pc DSS alum driveshaft and an old 2way diff.
Does my diff need reshimming?
Thanks for your help
wavess13 is offline   Reply With Quote
Old 10-24-2020, 07:56 AM   #2
tuzzio
tuzzio's Avatar
my alum drive shaft / old kaaz whines on decel.
Old 10-24-2020, 11:59 PM   #3
wavess13
Thanks for feedback. Whining i would not worry too much.
There is a loud clunk seems like the same noise as the movement from the play. Just wondering if this is normal for a 2 way diff and aluminum driveshaft
Old 10-26-2020, 09:47 AM   #4
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
mines does something similar, aluminum DS and a welded dif, I always assumed it was play between the pinion and ring gear and when u let of the gas instead of the pinion turning the ring gear the ring gear catches up and starts turning the pinion. mines not very noticeable tho
The Game
you lose haha
kyral is offline   Reply With Quote
Old 10-30-2020, 06:29 AM   #5
jr_ss
That is excessive side shaft play. I would check spec in the manual and get that resolved. Could be a faulty snap ring inside the diff.
Old 11-03-2020, 01:25 PM   #6
DiscountPirate
DiscountPirate is an unknown quantity at this point
I would tend to agree with a possible diff issue. You can take the half shafts out of diff but once they are in diff they should not be moving in and out like that.
DiscountPirate is offline   Reply With Quote
