![]() Just installed a autometer one i had sitting around. but i havent changed oil in 2000k miles roughly but.. i get between 10-25psi at warm idle... then full throttle.. i stopped at 6krpm.. about 55-60 psi could not see exact number but no higher then 60 and no where near the big 75... so if anyone could post what they are getting .. i dont think the gauge is broke? and how well does those nylon lines hold up ?
![]() Join Date: Dec 2002
you CAN overtighten the nylon lines and it will mess with your oil pressure. i think your best option is to get the braided stainless line they make for your gauge so you can just screw it on. but i got 22 psi warm idle and 60 psi at 3k rpm in neutral. thats where the car should be iirc.
www.stewartleask.com |
iunno for sure, i was almost positive it was autometer themselves. i saw it in an old summit catalog awhile back for imports.
your #s are low linja. i use 10w-30 and mine are as listed above. might wanna check your motor for leaks and check oil passages if you get the chance.
