Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 10-05-2020, 04:47 PM   #1
Krazy719
Krazy719 is an unknown quantity at this point
05 350z no signal to starter
Need help can?t find out why I have no signal to my starter I picked up the z as a shell & been putting everything together & just hella stumped it has a brand new started benched tested also swapped relays & ignition switch kick panel on driver side starter fuse is good lights up & can hear it switch on when key is turned all the way also hooked up starter straight to battery engine turns over no problem I go under the car to test if starter is getting signal I have a friend turn the key & nothing any help would be really appreciated but can?t think of anything else would a bad ecu cause this ?
Krazy719 is offline   Reply With Quote
Old 10-05-2020, 05:02 PM   #2
S14rebuild
Need to pull up wiring diagram and check the powerflow
Old 02-23-2024, 12:22 AM   #3
Dazaphymn
Dazaphymn is an unknown quantity at this point
Send a message via AIM to Dazaphymn Send a message via Yahoo to Dazaphymn
Have you considered checking the neutral safety switch, as it might be a potential cause for the lack of signal to the starter?
Dazaphymn is offline   Reply With Quote
