Old 08-27-2022, 09:50 AM   #1
rfbokle
rfbokle is an unknown quantity at this point
240sx exhaust (KA24E) - HKS Sport
Guys,
I have an 89 with a ka24e and looking at this HKS exhaust below. The thing is, in the HKS product page I am seeing this exhaust (HKS 31013-BN002) shows it is compatible with the KA24DE and the SR20DET. Not seeing KA24E. I do see that the HKS 32003-KN002 has compatibility for the KA24E, but that is not dual tip, single can and I want dual tip. Does anyone know if the HKS 31013-BN002 will work with the KA24E?
https://www.hks-power.co.jp/en/produ...duct/1/maker/2
https://www.amazon.com/HKS-31013-BN0...A1P4Q6WVP7QBZ3
Thanks in advance!
Bob
rfbokle is offline   Reply With Quote
Old 08-27-2022, 10:17 AM   #2
mav1178
mav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfection
all S13 catback exhausts are the same, as long as your catalytic converter or test pipe is still in the same location as stock.
also, if you are in the US I can get you a price shipped
Edit: on second thought, you should just buy from the sellers on Amazon. they are lowballers, not worth it to fight over literally $5 in profit.
Complete list of in stock items here:
https://bit.ly/3O5TOU5
Distributor for Nismo, ORC, and discontinued genuine Nissan parts.
Authorized dealer for Oakley -- PM me for the best prices!
[email protected]
mav1178 is offline   Reply With Quote
Old 08-27-2022, 10:24 AM   #3
rfbokle
Thanks! What size is the stock cat flange? Not sure if this hks sport will mate up to it. I think the piping on the hks is 3" and I think the 240sx flange is like 2.5", not sure though.
Old 08-27-2022, 10:32 AM   #4
mav1178
doesn't matter, all the catback exhausts have the same 2 holes for use with stock or stock replacement cats or test pipes.
for nonturbo exhausts it is the same 60.5mm piping all the way through
[email protected]
Old 08-27-2022, 10:38 AM   #5
rfbokle
Are you saying the flange is 2.5" on the HKS and will mate up to the stock cat? So i just need stock gaskets for it?
Old 08-27-2022, 10:43 AM   #6
rfbokle
Yeah I see pipe size is 3" for the HKS Sport. If the stock flange is 2.5" not sure how that is going to mate up correctly unless the flange on the HKS piping to the cat is 2.5".
Old 08-27-2022, 11:35 AM   #7
mav1178
You're overthinking it...
the distance between the two studs on the catalytic converter is the same for the two holes on OE and aftermarket exhausts.
The gasket above is the stock gasket between the catalytic converter and the exhaust. The exhaust comes with gaskets but either way, you don't need to worry about this.
again: if you have a stock, stock replacement, aftermarket catalytic converter, or any test pipe that replaces the cat 1:1 with the same bolt holes, the exhaust will fit. that's all. even 3" aftermarket exhausts will still mate up to the same two studs found on the stock setup, so the flange will only be so big.
[email protected]
Old 08-27-2022, 12:08 PM   #8
rfbokle
Gotcha, thanks so much my man. Really appreciate the help on this. I threw an exhaust on an old 240 years ago and couldn't remember if I had to do anything special here with the install.
Old 08-28-2022, 06:20 AM   #9
burnsauto
burnsauto's Avatar
...HKS makes a duel tip sport exhaust for the s13? I've never seen it, only single tip for the sport.
