Old 09-08-2022, 08:55 AM   #1
sash357
sash357 is an unknown quantity at this point
S14 rear calipers vs Z32 rear calipers for drag wheels
Hi,
I was wondering if anyone knows how much larger the Z32 rear calipers are compared to the stock s14 rear calipers.
I know Weld has wheels that will fit the S14 but not sure if they will clear the Z32 calipers. Anyone know or have some helpful info?
Thank you,
sash357 is offline   Reply With Quote
Old 09-08-2022, 10:32 AM   #2
Om1kron
Om1kron's Avatar
hate to be the bearer of bad news, but they're much larger. nothing astronomical but if you're trying to figure out things for stuff you haven't purchased yet or not even in your line of sight financially. best not to fantasize about them fitting or not until you have them in your possession.
Dickhead answer, sure. But this could've been asked in the small questions thread.
Wayne Edwards
https://om1kron.blogspot.com
Old 09-08-2022, 11:07 AM   #3
tuzzio
tuzzio's Avatar
As much as it pains me to say this, join the "strictly drag 240s" page on facebook and ask them. fuck facebook.
Old 09-08-2022, 01:03 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
but what do 240's in women's clothes have to do with brake clearance???
Old 09-08-2022, 08:24 PM   #5
sash357
I swapped to a full 5 lug setup and already did the z32 brakes in the rear. I?m trying to avoid going back but might have to. Not really fantasizing here but trying to see what works best with the least amount of work.
Also, if I’m looking at weld wheels for a drag setup, don’t think I’ll have an issue financially.
Old 09-08-2022, 09:02 PM   #6
jr_ss
Also, if I?m looking at weld wheels for a drag setup, don?t think I?ll have an issue financially.
If you completed the brake swap, wouldn?t you have the S14 calipers to measure the differences between them both? One caliper is a sliding single piston unit, the other is a fixed twin opposing unit. Spoke design plays a major part in this. Most of the drag guys have the simplest brake setup to shed weight.
Old 09-09-2022, 09:03 AM   #7
sash357
I moved about a few months ago and not sure if I still have the old rears. Haven't been able to find them yet. Figured this might be easier because if I can't find them, I'll just buy a pair of s14 rears but keep everything else the same as it is now. Not sure if the bigger rotor with smaller caliper would be an issue but then I guess I can just buy a stock size rear rotor.
Trying to maintain better braking but might have to switch back to the old rear calipers for the Welds to fit. Then gotta figure out the front fitment after.
Old 09-12-2022, 08:22 AM   #8
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Have you tried looking up Z32 fitment wheels to see if they match up? Stock S13 15" wheels will clear z32 calipers, so it's really comes down to spoke design on the wheels you're looking at.
LoSt180 is offline   Reply With Quote
Old 09-12-2022, 08:50 AM   #9
sash357
I've tried fitment about the same weld wheel on a Z32 and have had no luck. I know real street has the welds and states it fits the S14. I've reached out and they have no idea if it'll fit a Z32. I know spoke design can be an impact but its almost a guessing game between spoke design and fitment.
I'm not trying to spend almost 800 on one wheel to chance fitment and then be stuck with it. That's why I was hoping someone might have an idea.
Looks like I'll just buy the ones that fit the S14 and then swap our the rear calipers if needed.
Old 09-12-2022, 09:16 AM   #10
tuzzio
tuzzio's Avatar
Old 09-12-2022, 01:52 PM   #11
sash357
Thank you for posting the FB post. I don't use FB so I couldn't search on there. I am running Import Drag Solutions coilovers and they did mention running 6.5 but would require pulling fenders on a 9 wide. Seems like this might be pushing it. I was hoping to run a 15x8.
Wonder what the difference could be.
Old 09-13-2022, 03:45 AM   #12
tuzzio
tuzzio's Avatar
If you run the same back spacing, you should have about 3/4" more clearance with a 8" vs a 9.5".
However, height and tire size all come in to play here. You're not afraid to drag the car, but youre afraid to pull fenders?
Old 09-13-2022, 09:25 AM   #13
sash357
Not afraid to pull the fenders, just a preference.
Not sure what that has to do with the willingness to be drag/roll racing when its built for it.
Old 09-13-2022, 11:41 AM   #14
jr_ss
Why not get the 8?s and throw a spacer on? You?ll have to get different studs anyway to run the Welds?
Old 09-13-2022, 12:26 PM   #15
sash357
I've always been concerned with running spacers with higher horsepower. Most people I know don't seem to run them and have been advised not too.
Old 09-14-2022, 07:44 AM   #16
jr_ss
Weld spacers to wheels, no issues. I would agree with bolt on spacers, but slip on makes no sense. 3-5mm is probably all you’ll need.
Old 09-14-2022, 11:27 AM   #17
sash357
Sounds good and thank you.
Looks like I'll have a few options either way whether its spaces, possibly going wider or just putting the old calipers back on.
Trial and error at this point.
