Old 10-11-2022, 02:06 PM   #1
Trixzim
Trixzim will become famous soon enoughTrixzim will become famous soon enoughTrixzim will become famous soon enoughTrixzim will become famous soon enough
Send a message via AIM to Trixzim
s13 90 Ka24e Smog failed stock car
Hello,
I went to get my 1990 240sx ka24e smogged today and I failed. Does anyone have an Idea what is causing this?
Failed with this info:
Idle speed CO was 6.13% (Greater that 1.20%)
Idle speed HC Was 683 (Greater than 220 Parts per million)
Do you think my coolant temperature sensor is bad? (Replaced 10/12/22didn't help with OEM sensor)
Or do u think it has to do with thermostat, water pump, and fuel pressure regulator?
This is a picture of my stock engine bay:
Few Things I noticed with my Car:
-Plugs are wet and seemed to be cover in gas. Running rich (You can smell it)
Old plugs
-When I tap the gas and let go, the idle drops and kind of bogs
-The engine seems to be running hot but the gauge is showing about a quarter
Things I replaced:
Engine temp sensor
O2 Sensor (NTK 02 sensor)
New OEM Dizzy and rotor
New spark plugs and wires ( NGK wires and NGK Iridium plugs )
New Air filter
New fuel filter
Timing was check and its a 15 B.T.D.C
Thanks,
Trixzim is offline   Reply With Quote
Old 10-11-2022, 02:23 PM   #2
relaxamigo
relaxamigo's Avatar
relaxamigo is an unknown quantity at this point
Your car is running rich, hence the high Hc content.
Tips to bring the A/F mixture back to OEM spec:
- new OEM coolant temp sensor
- check ignition timing and set to OEM spec
- check fuel pressure
- replace fuel pressure regulator
- check injectors for leaks (rubber O-rings go bad)
To address cooling issue:
- wire a good water temp gauge and diagnose from there. stock unit sucks, you don't even know what temp your car is at
To pass your emissions test:
- "check" all the things in the first list on my post
- inspect catalytic converter (if this is clogged/fucked, it won't clean your emissions) you can replace with a universal for less than $50, but you'll need to weld
relaxamigo is offline   Reply With Quote
Old 10-11-2022, 03:10 PM   #3
Trixzim
s13
What fuel pressure regulator would you recommend?
Will the auto zone one work ? GP Sorensen Fuel Pressure Regulator 800-171
Old 10-12-2022, 05:15 PM   #4
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
you can replace it with a universal for less than $50, but you'll need to weld
Not in California. CA "compliant" ones are at least $200.
ZenkiKid is offline   Reply With Quote
Old 11-07-2022, 04:29 PM   #5
Trixzim
s13
did you replace the sensor for the gauge or the sensor for the ecu?
there are two sensors, next to each other.
one feeds signal to the ecu, and the other is just for the gauge on the instrument cluster.
Okay, I figured out whats going on but I don't understand whats happening. Please help me understand.
I make sure the car is running at operating temperature. Then I set my timing to 15 B.T.D.C with the TPS unplugged both connectors unplugged (unplugged it with car off). I turn off the car and plug the TPS back in. I start the car and check the timing again and its retarded to 10 degrees. It loses 5 degrees of timing some how and dumps more fuel?? limp mode??????? The only way I can get the timing to go back to normal is loosen the TPS and adjust the volt up and then back to where it was at .50. Then the timing is back at 15 degrees and the cars runs well, but once I turn off the car it does the same thing again where it runs at 10degrees in a limp mode.
I also replaced the TPS with a new one and does the same thing. Anyone have any ideas?
Old 10-12-2022, 10:22 AM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
also, a fresh oil change right before your smog check can be the difference between a pass and a fail.
Old 10-12-2022, 09:04 PM   #7
Trixzim
New oil, New spark plugs, New dizzy, New rotor, checked time, new air filter, new fuel filter, new o2 sensor, new temp sensor now.
I think I'm going to replace the MAF now, fuel cap, replace the o-rings on injectors and have them cleaned. Then maybe get a new fuel regulator. I'm going to take off my cat and check it out too.
Old 10-12-2022, 12:07 PM   #8
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
You can check the egr ports on the intake manifold there hex caps each runner has one plug
Old 10-12-2022, 03:09 PM   #9
PoorMans180SX
PoorMans180SX's Avatar
So the 25 year rule doesn't apply to state smog eh? I didn't know that.
Old 11-07-2022, 08:10 PM   #10
mav1178
mav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfectionmav1178 is close to perfection
25 year rule never applied to any state smog, it is (and always was) a federal rule.
Complete list of in stock items here:
https://bit.ly/3O5TOU5
Distributor for Nismo, ORC, and discontinued genuine Nissan parts.
Authorized dealer for Oakley -- PM me for the best prices!
[email protected]
mav1178 is offline   Reply With Quote
Old 10-13-2022, 09:32 AM   #11
brndck
brndck's Avatar
Things I replaced:
Engine temp sensor
Thanks,
Old 10-13-2022, 04:22 PM   #12
Trixzim
Sensor for ECU and tested to make sure it works.
Old 11-08-2022, 07:03 AM   #13
AKADriver
AKADriver's Avatar
Some states have their own separate "25 year rule." We do in Virginia, separate from antique registration which also becomes available at 25 years. (Antique registration just gets me a tax/fee break in exchange for keeping mileage under 2500/yr.)
coolant, idle, ka24e, smog, stock
