Old 10-30-2024, 09:19 AM   #1
connor116
connor116 is an unknown quantity at this point
s13 1991 2JZ 240SX Hatchback
Hello All!
This is a pristine, zero rust, 2JZ-GTE swapped 1991 240sx. Zero corners were cut during this build and the car has zero issues/leaks. Everything works on the car, right down to the automatic seatbelts!
To give you a birds eye view of the build, the car has a fully built 2JZ-GTE-vvti engine making 600WHP on 93 octane (However the driveline is built to handle 1000+HP on E85). The engine only has 1500 miles on it and everything on it is brand new. The engine is mated to a 6-speed Grannas Racing T56 Magnum F transmission GR700. The entire suspension and braking system on the car has been upgraded (big brake kit, 800+HP axles, etc.). It weighs just shy of 2800lbs and has been corner balanced. Nearly everything on this car is brand new and it has zero issues. It drives like a dream and I used it as a daily driver over the summer. It is only garage kept and has never seen rain. Everything on this car operates as it should, even the speedometer is properly calibrated which is rare on swapped 240's! No rattles or funny noises either. The car even comes with a spare tire that matches the other wheels/tires (Enkei RPF1 17x9 w/ Dunlop Direzza ZIII 245/40/17).
The full modification list is in the last 3 pictures of the listing. Please contact me for extra pictures/information. I'm selling because I would like to move on to another project.
Listing: https://www.facebook.com/marketplace...44475232060631
connor116 is offline   Reply With Quote
2jz
