Old 11-07-2003, 01:22 PM   #1
ShiftLock
ShiftLock is an unknown quantity at this point
Power Window Problem
Earlier today as my window was going up, it sounded like the motor just stopped working and the window went straight down. The motor makes a whining noise if i try to raise it back up. Anyone know how i can fix this? Do i have to go to nissan or can i just buy the part at a auto store and have a mechanic do this? I need to get it fixed asap as there is no space in my garage and it might rain tomorrow.
Thanks
AE86 Corolla
1990 240SX Hatchback
ShiftLock is offline   Reply With Quote
Old 11-07-2003, 01:25 PM   #2
HiPSI
HiPSI is an unknown quantity at this point
Send a message via AIM to HiPSI Send a message via Yahoo to HiPSI
either the raising mechanism broke (common on nissans) or the window popped out of place (hope it didn't break). i'm not 100% sure of which setup the 240's have, but if they're like the other 5 nissan windows i've fixed, there's a small plastic tab on a cable that probably broke. it's an easy fix with a little MacGuyver ingenuity though (i drilled a very small hole and pushed a cotter pin through and bent it around, works like a champ).
SR motor set/clip $2500+, FMIC kit $700+, Downpipe $100+, 3" exhaust $500+, Misc install parts $100+, Shop labor for install $1000+ and you still only make 220rwhp for $5000
so what's so CHEAP about the SR swap again?
HiPSI is offline   Reply With Quote
Old 11-07-2003, 09:58 PM   #3
Natty
Natty is an unknown quantity at this point
I know exactly what happened. The bolt or bracket thet hold the actual glass window to the rail broke. The noise is the motor going up and down. You need to get a bolt and bolt it back up. Kind of hard to do once person becuase it's a tight fit and you have to align it a bit, but it is a super easy fix. Good luck.
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 01-06-2005, 02:47 PM   #4
jeprokz
jeprokz is on a distinguished road
sorry to bump this back up, but this happened to me a few days ago. the bolt on the glass that attaches to the regulator broke off in two. so do i just keep turning the broken bolt and it will eventually come off, or just pull it all the way out, or do i need a special tool? i'm afraid i might break the glass if i go about this the wrong way. oh and i most likely have to pull out the glass out huh? any feedback would be greatly appreciated. thanks.
jeprokz is offline   Reply With Quote
Old 01-06-2005, 02:57 PM   #5
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
The bolt that is attached to the window sheared? You might have to get a new window if that's the case. But I'm not sure what you are talking about. Post pics if you can!
thelinja is offline   Reply With Quote
Old 01-06-2005, 03:27 PM   #6
projectRDM
projectRDM's Avatar
The bolts press out of the glass. Fine someone who's got a good window and pick it up, or find a salvage yard with a broken window and nab it the part you need.
FORMERLY R240NA
Old 01-06-2005, 04:50 PM   #7
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
or you could try JB cold weld..
I'm here to inform not to conform...
s14 blacktop is offline   Reply With Quote
Old 01-07-2005, 02:19 AM   #8
idlafie
idlafie's Avatar
S14's window glass are held to the window regulator by two bolts. Don't ask me why but the rear bolt, (closest to the door latch), on the window regulator assembly has a tendency to break. Finding that stupid bolt is a pain....dealer won't sell it unless you buy the entire glass.
Anyhow, I've attached a photo showing what the bolt looks like. Other than an auto glass shop, anyone have an idea where you could find a bolt like this??
ID
Old 01-07-2005, 02:20 AM   #9
idlafie
idlafie's Avatar
JB cold weld won't work...see picture of bolt...
ID
Old 01-07-2005, 01:07 PM   #10
jeprokz
thank you for all the replies.
idlafie: what up man? does that mean u don't have that bolt anymore? if you do, can i pick it up? if not, do you still have that driver side glass? i'm willing to buy. also along w/ the blower resistor? i'd like to come by and maybe we can stop by that burger place again. wouldn't mind seeing that cute girl that was workin there last time . or i can just pick up parts. i also emailed you. don't know if you got the previous one.... thanks
Old 01-07-2005, 01:20 PM   #11
s14 blacktop
my bad I didnt look close enough on my window when I changed it..
