Old 01-08-2005, 10:19 PM   #1
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
Milled Head Twice... Compression Probs??
I have had my head milled twice. After I blew my latest head gasket the car is running like a lawn mower. I have several mods...everything but new pistons basically. I'm running a stock compression head gasket and am thinking that the head milling has raised the compression too much and it runs terribly. Feasible?
Ryan
Pudula is offline   Reply With Quote
Old 01-08-2005, 10:35 PM   #2
Kid Zelda v2
Kid Zelda v2 is an unknown quantity at this point
HOt road style
run a thicker head gasket 1.5
lates
Kid Zelda v2 is offline   Reply With Quote
Old 01-08-2005, 10:43 PM   #3
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
How many thousandths was it taken down in whole?
wootwoot is offline   Reply With Quote
Old 01-08-2005, 11:43 PM   #4
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
Ryan
did you run a compression check ?
also check the coolant and oil too see if coolant or oil in the water
pull the spark plugs check the tips of too try too narrow down the prob.
racer98 is offline   Reply With Quote
Old 01-09-2005, 12:19 AM   #5
weirdstyles.net
This guy...
weirdstyles.net's Avatar
weirdstyles.net is an unknown quantity at this point
Send a message via AIM to weirdstyles.net
Try to be more descriptive of the running condition. Let see if we cant pin point this...
My project car...
From dust you were born,
And to the ashes you return ~ Kill Switch Engage
Family Guy
Quagmire: Hey, how old are you sweet thang?
Connie: 16.
Quagmire: 18? Alllll-right!
Connie: Mommmm!
Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy!
weirdstyles.net is offline   Reply With Quote
Old 01-09-2005, 03:06 AM   #6
Pudula
Bear with me here...
The head gasket was just replaced not too long ago. I have new ARP head studs in there, torqued to spec. The timing chain is set on the proper mating marks, although when the timing light is put to it, it is not exactly dead on - another indication of a milled down head, i hear. The spark plugs are covered with carbon deposits even though the car has only idled since the head gasket install. The running condition is as follows: Starts right up, runs extremely choppy and sounds somewhat like a muffled lawn mower. When revved up, the timing changes because it is a VVT, and when the rpms start climbing well above idle, the choppiness subsides. The compression numbers were at about 145-150 across the board. Please keep asking questions about the situation so I can help you help me...This beast is about a year over-do to be on the road and about 17 grand over budget!
Thanks In Advance,
Ryan
P.S. - here are the engine mods just in case you need them to help narrow things down: z32 mafs, 740cc injectors, z32 fuel pump/filter, JWT ecu, 264 cams, stock compression head gasket, greddy valve springs, gt2871r turbo, hks manifold, koyo radiator, 3-3.75 inches all the way back w/ straight pipe, apex'i intake.
Old 01-09-2005, 03:20 AM   #7
mikespeed95
mikespeed95 will become famous soon enoughmikespeed95 will become famous soon enoughmikespeed95 will become famous soon enoughmikespeed95 will become famous soon enough
Send a message via AIM to mikespeed95
im guessing you ahve a xx year sr? why do you ahve 2 mafs?
i like drift racing
mikespeed95 is offline   Reply With Quote
Old 01-09-2005, 10:21 AM   #8
Var
Var's Avatar
Send a message via AIM to Var
my 2 cents is that high compression will not make your motor run choppy. and your compression isnt high..150psi? that's on the low side of a healthy motor. Sounds like your valve timing is off and there is an overlap in intake and exhaust valves being open so it's running like you got wild cams and could also explain losing compression. do you have stock cams? did you double check to see if they are installed right? that's all i can think of. of course the best thing would be to have someone look at it but we'll help you all we can.
mikespeed95 - he never said he has 2 mafs', the last (s) is for sensor
Hi
Old 01-09-2005, 10:24 AM   #9
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
Originally Posted by mikespeed95
One of us needs a name change haha
TokyoNights is offline   Reply With Quote
Old 01-09-2005, 01:11 PM   #10
Pudula
I agree that it seems like timing is off, obviously... But once the head is milled down, the timing will be off naturally because the the distance from the main crank gear and the cam gears is shortened. I'm not sure how much this effects but i know that is one reason to have adjustable cam gears (which I don't). So my suggestion to me would be to get the thicker 1.5mm gasket to correct some of this timing retard. What do you guys think?
Ryan
The other option is to drive it off a cliff and get my life back.
Old 01-10-2005, 10:19 AM   #11
Var
Var's Avatar
arent you the guy that's been having problems with your motor forever? i feel sorry for you man. You've spent 17 grand, i wonder how much driving enjoyment you've actually felt from the thing.
Hi
Old 01-10-2005, 10:36 AM   #12
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
actually he said 17k over budget, so therse no tellin how much he relaly spent so far?
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 01-10-2005, 10:49 AM   #13
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
Did you try checking to see if your spark plugs are tightened down..sounds like what my s14 sr did because my sparks werent tightened on good enouge,
for the first 3000 RPM runs rough (like its not firing all cylinders) and then after 3000 rpm it runs really smooth and revs really easily..
I'm here to inform not to conform...
s14 blacktop is offline   Reply With Quote
Old 01-10-2005, 07:17 PM   #14
Pudula
I'm THAT guy, yes. I have driven it for about 400 miles total in the last year since I started the swap. As far as budget, I'm about 5k over, but I'm up to 17k in mods...just thought I'd be more dramatic. The spark plug idea I have tried...
I'll get it resolved one day. One sweet sweet day.
Someone still MUST have something to suggest...
Ryan
Old 01-10-2005, 08:32 PM   #15
tegasaurus
tegasaurus is an unknown quantity at this point
you said the option yourself.
westboroughpimp sounds right to me, but then again i suck at cars and im just having someone put my sr20 in for me.
tegasaurus is offline   Reply With Quote
Old 01-11-2005, 12:30 AM   #16
Var
Var's Avatar
have a pro tune it. you've spent so much. it'll be worth whatever they charge
Hi
