Old 01-10-2005, 08:48 PM   #1
Jcamel
Jcamel is an unknown quantity at this point
Stuck sparkplugs
Hey,
I was going to change my spark plugs today and to my surprise they will not come out. I guess the previous owner didn't lubricate them or something. The question is should I just try to force them out? I've changed spark plugs before and they usally just twist off with slight force. Any suggestions?
thanks.
Jcamel is offline   Reply With Quote
Old 01-10-2005, 08:55 PM   #2
bleach8484
bleach8484 is an unknown quantity at this point
I would try putting a little force on em, with a decent spark plug socket and a ratchet with some leverage, And just pray to got they arent cross threaded or anything. Ive never had a plug twist off on me or break, the aluminum head usually gives before the plug does.
bleach8484 is offline   Reply With Quote
Old 01-10-2005, 09:23 PM   #3
Id-
Id-'s Avatar
Id- is an unknown quantity at this point
put some liquid wrench on the top of them and let them soak for a bit; try it then with just your normal socket that you normally use
if that doesnt work, then step up to a 1/2" breaker bar and try from there
95 Lexus SC300 5-speed
-DD pimp car
92 Nissan 240sx base coupe
-clean KA24DE swapped in
-GTIR T28
-Big FMIC
-565cc STi Injectors w/ Z32 MAF
-J30 VLSD w/ subframe spacers
-RPS Max clutch
-3" turboback
-PLMS Daughterboard on modded ECU
Id- is offline   Reply With Quote
