Old 08-20-2009, 05:13 PM   #1
T_wei
T_wei's Avatar
T_wei is an unknown quantity at this point
Clutch stuck to the floor after driving bad slave?
It's been getting worse and worse. After i got a new clutch i notice my clutch sometime after driving be slightly lower than before, i just push it out with the top of my feet. It's been getting worse and worse. Im not having trouble shifting at all, just in the morning or after i drive and park the car for awhile, the clutch pedal would be literally stuck to the end with like maybe half an inch to move... i pull it out and pump it once and it returns to normal position.
I bled the clutch already and its still doing that. Is my slave going out?
T_wei is offline   Reply With Quote
Old 08-20-2009, 05:17 PM   #2
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
Sounds like you may not be bleeding it correctly. Did you install the clutch and bleed it yourself?
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 08-20-2009, 06:03 PM   #3
T_wei
T_wei's Avatar
no mech installed the clutch, i bled the clutch.
Old 08-20-2009, 06:09 PM   #4
MrFixIt
MrFixIt's Avatar
MrFixIt will become famous soon enoughMrFixIt will become famous soon enoughMrFixIt will become famous soon enough
I know sooooo manny people, myself included, who have this problem. Incomplete clutch pedal return. I've heard a ton of oppinions on how to fix it. Some say bleed your system again. Some say you need a new master/slave. The most interesting solution I've heard of so far claims that a tiny plastic clip located somewhere up in the clutch pedal assembly breaks and you need to get a new one. It's apparently a $5 part at a dealership, a buddy of mine showed me one, still in the little nissan parts bag.
So basically, from what I've heard, it could be due to any number of things hahaha. Good luck with fixing it though. It does get annoying after a while...
MrFixIt is offline   Reply With Quote
Old 08-20-2009, 09:13 PM   #5
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
could be a couple of different things. you just have to use process of elimination
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 08-20-2009, 10:38 PM   #6
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
check that little plastic part he is talking about... if you see it damage well then that can be the problem its only $5. If thats not it bleed the clutch again. Then move on if thats not the problem.... replacing slave or clutch MC. Im not sure but doent the pedal have a return spring? process of elimination brotha
zylvia213 is offline   Reply With Quote
Old 08-20-2009, 10:42 PM   #7
Blues13
Blues13 is an unknown quantity at this point
Sometimes with a aftermarket clutch, the little clutch box near the slave cylinder makes the pedal feel mushy.. take the clutch box out and reroute the line.. It should improve the clutch pedal feel.
Blues13 is offline   Reply With Quote
Old 08-20-2009, 11:05 PM   #8
ReLiC
ReLiC is an unknown quantity at this point
This used to happen on my old 240 whenever i let my cousin drive it =/
Clutch would sink waaay in, but after a few days of driving it, it would go back to normal.
ReLiC is offline   Reply With Quote
Old 08-20-2009, 11:39 PM   #9
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
check the master cyl behind the pedal.
i know mine has a slow leak from there. my pedal goes out after like 3 months until i fill the master cyl back up. theres a stain on my floor mat from the fluid :P
flip3d is offline   Reply With Quote
Old 08-21-2009, 11:15 AM   #10
T_wei
T_wei's Avatar
HA i never heard that before ill check, is it located on where the clutch pedal pivot?
and also i don't think its leaking inside the car
Old 08-21-2009, 11:25 AM   #11
S13Yosh
S13Yosh's Avatar
S13Yosh is an unknown quantity at this point
Try replacing ur clutch damper or eliminating it..i had a similar problem. i bled and bled. i also changed 2 masters and a slave. same problem. i swapped the clutch damper and sure enough it was it. i would recommend eliminating it. much more direct feel
S13Yosh is offline   Reply With Quote
Old 08-21-2009, 11:30 AM   #12
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
well i got lucky...my slave went bad right when i pulled into my work parking lot.
clutch pedal went right down to the floor lol. so i inspected it and there was a pool of fluid under my slave...repalced the slave and bled.
so thats' my experience.
clark is offline   Reply With Quote
Old 08-21-2009, 11:36 AM   #13
MrFixIt
MrFixIt's Avatar
I'm not realy sure man, sorry. Try searching for it.
